grill surround replacement - Ford Truck Enthusiasts Forums
Old 04-13-2014, 07:20 PM
supertuff supertuff is offline
supertuff is starting off with a positive reputation.
whats the easiest way to access bolts to remove grill shell ? or , how do you do it ?
thanks
Old 04-13-2014, 10:27 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
No tricks... remove the grill inserts and a shot of PB Blaster (or equivalent) the day before. Then undo the bolts.
Why the question? It's rather a simple task to generate a question about how to do it....
Old 04-13-2014, 10:33 PM
g-man-75 g-man-75 is offline
g-man-75 is gaining momentum as a positive member of FTE.
1/4" nut driver in one hand, cold barely soda in the other. Piece of cake
Old 04-14-2014, 07:08 AM
79 f150. remove grill inserts ? i dont see how to get to the bolts. the ones on each side by the headlights. three on each side . the bolt heads are on the backside of the grill.
Old 04-14-2014, 07:37 AM
Bud Mud Bud Mud is offline
Bud Mud has a very good reputation on FTE.Bud Mud has a very good reputation on FTE.Bud Mud has a very good reputation on FTE.
Quote:
Remove the plastic fender wells,come in under the fender with a long exstetion and socket.
Old 04-14-2014, 11:27 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Old 04-14-2014, 12:20 PM
HIO Silver's Avatar
1/2-inch combo wrench and 1/2-inch socket on a ratchet...
.......It goes without saying but here's a visual:
Old 04-14-2014, 12:39 PM
gfburke's Avatar
gfburke gfburke is offline
gfburke is starting off with a positive reputation.
On top of this question, I've noticed the round light grills (pre-79) and the surrounding area look like they would bolt right up to a 79 as a direct replacement. I like the rounded look a bit better and I need to replace anyways. Just direct swap?
Old 04-14-2014, 01:27 PM
HIO Silver's Avatar
Quote:
Not quite direct because of different headlight buckets which, IIRC, mount in slightly different locations.
Otherwise, very low on the difficulty meter... about a 2 out 10.
Old 04-14-2014, 01:43 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Your arm will fit back there. Take the rubber shields off of the top of the grill.
Old 04-14-2014, 03:57 PM
gfburke's Avatar
Right on. So finding a 77 to strip, just grab all dat up in there eh.
Old 04-14-2014, 05:37 PM
Round headlight parts for 1978 are not the same as 1977, except for the headlight retaining ring and the seal beam.
Grille Question?? TBird Larry 1961 - 1966 F-100 & Larger F-Series Trucks 21 08-17-2014 01:10 AM
Are all 53-56 Grille supports the same? clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 02-26-2014 08:24 PM
F350 GRILLE BAR REPLACEMENT artfuldodger 1999 to 2016 Super Duty 1 12-08-2013 08:12 PM
BILLET GRILLS? 88PONY 1987 - 1996 F150 & Larger F-Series Trucks 4 08-15-2013 04:59 PM
Screen behind the Grill sltrrco Excursion - King of SUVs 18 05-26-2008 01:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
