Replacing Oil pump 64 F-100 292 - Ford Truck Enthusiasts Forums
Old 04-13-2014, 03:25 PM
Bigfatsteve Bigfatsteve is offline
Bigfatsteve is starting off with a positive reputation.
Hey Ford heads....I was thinking about replacing the oil pump on my sons 1964 F-100 292 v8. I noticed today it was on the outside of the motor! How cool is that! I was wondering if there was any trick to it, meaning if I unbolt it, is there any drive shaft parts that I need to be careful of when removing it or be mindful of something when I re-install the new one? Rockers are a little loud and i am wondering if enough oil is getting up there. 40 pounds oil pressure now, no smoke issues.
Thanks Steve
Old 04-13-2014, 03:50 PM
skidoorulz's Avatar
skidoorulz skidoorulz is offline
skidoorulz is starting off with a positive reputation.
The oil pump drives off the distributer which drives off the cam. The shaft is a hex and will probably come out when you remove the pump. just put it in the new pump and make sure it goes back in the bottom of the distributor when you bolt it down. You may have to turn the motor so the shaft will line up to the distributor.
Old 04-14-2014, 09:53 AM
Oil Pump
Hey thanks for the tip, it is appreciated!
292 oil pressure Danrweaver Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 02-21-2017 04:00 PM
Oil amount for 292 Y Block MrLiam 1961 - 1966 F-100 & Larger F-Series Trucks 19 01-11-2017 07:14 AM
1964 f100 240 motor swap dodgers72 1961 - 1966 F-100 & Larger F-Series Trucks 14 05-05-2015 08:58 PM
Bell housing Big Block Boy Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 13 02-08-2007 07:30 AM
292 Oil Pump Pickup Tube Dave1932 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 01-20-2007 05:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
