Replacing Oil pump 64 F-100 292
Old 04-13-2014, 03:25 PM
Bigfatsteve's Avatar
Bigfatsteve
Bigfatsteve is offline
Hey Ford heads....I was thinking about replacing the oil pump on my sons 1964 F-100 292 v8. I noticed today it was on the outside of the motor! How cool is that! I was wondering if there was any trick to it, meaning if I unbolt it, is there any drive shaft parts that I need to be careful of when removing it or be mindful of something when I re-install the new one? Rockers are a little loud and i am wondering if enough oil is getting up there. 40 pounds oil pressure now, no smoke issues.
Thanks Steve
Old 04-13-2014, 03:50 PM
skidoorulz's Avatar
skidoorulz
skidoorulz is offline
The oil pump drives off the distributer which drives off the cam. The shaft is a hex and will probably come out when you remove the pump. just put it in the new pump and make sure it goes back in the bottom of the distributor when you bolt it down. You may have to turn the motor so the shaft will line up to the distributor.
Old 04-14-2014, 09:53 AM
Bigfatsteve
Oil Pump
Hey thanks for the tip, it is appreciated!
jeff8362000
11-09-2009 08:59 PM
General Lee
08-30-2007 10:15 PM
wckdclwn911
04-21-2004 07:23 AM
bigvinnie
03-27-2004 06:44 PM
nlee1188
11-20-2002 10:33 AM
Quick Reply: Replacing Oil pump 64 F-100 292
