Bronco Graveyard For Limited Slip Clutches?
Im trying to locate where to get the clutches for the sterling/ford 10.25 limited slip rear end, i will be rebuilding it this summer along with the rest of my suspension if i can locate the clutches.
bronco graveyard list several different types for the 10.25 rear end, im assuming mine is stock, doesn't look like there have ever been any changes made to it. so how do i know which ones i need without getting it disassembled already, i don't want to tear it down unless i know i have all the parts available to get it back together, i really dont want to get everything tore down to find out that parts are no longer made.
here is a link to bronco graveyards site where the different clutch sets are listed.
1980-96 Ford Truck/Bronco 10.25" Differentials & Parts - Rear Axle Ford 10.25"
if anyone has done this before and has a better source please feel free to share it im open to any source as long as they are reputable and parts are of quality.
I also found them by yukon at summit racing, so ill probably go that route unless someone can give me some good reviews on bronco graveyards clutches.
http://www.summitracing.com/parts/yga-16099
Yes thats what i went with. It works just like a limited slip, only it has helical gears. It doesnt feel any different on dry pavement since it is not a locker. Im still getting used to the 4:10 gears though every now and then i take it out of 5th cause i think there should be another gear.
on
1 Post
Milwaukee1979F150
03-16-2010 06:30 PM
