Making progress on "son of mater" - Ford Truck Enthusiasts Forums
Old 04-13-2014, 12:14 AM
Notmeofficer's Avatar
Notmeofficer Notmeofficer is offline
Notmeofficer is gaining momentum as a positive member of FTE.
79/73 f350
Converted to round eyes
Stumpuller new 460
Old school rat rod paint but all new underneath,, Ill probably just clear the orginal paint and faded logos.. I like that look.
Truck has 79k original miles and came from a shop in central Calfirnia. The original motor had a miss.. I suspect a burned valve
Didnt take the cab off but stripped it down and then sandblasted everything.. Painted it numerous times underneath.. right down to the drips the factory made... gloss black vs frame black
I replaced anything that was worn as I went along.. Ill reuse a part if its excellent shape otherwise why do the effort. I throw away buckets of rusted bolts on every project of mine...
I fatmatted the interior.. no rust.. ah California trucks
I pulled the air and converted it to manual heat using .250 aluminum to fill the hole
3g conversion.. if thats not enough I have a leece neville 250 amp 100% duty alternator sitting on a shelf
New front coils and kyb shocks. poly bushings
Oversize aluminum rear end cover
Killer c6 with deep pan and huge cooler(s)
New premium brakes all around,, super stops in the front.. commerical shoes in the rear.
For some reason when I took out the cluster it just disintegrated in my hands..literally plastic dust.. perfect excuse for dakota gauges
I found some ford truck fleece pattern of all the fords from the the model t to now... Im going to use it as my headliner
The wrecker body was a holmes period piece always on the truck. Other than the hydralic units needing serious seals and a new cable it was acceptable. I found a new lense for the single gumball...it was a hard find. Im going to outfit it with LED floods to replace the old school 100 w backup floods. I have made a number of changes in updating the wrecker body. I will xtrmeliner the entire inside of the bed once all the kinks are worked out and Im sure what I want in it.
Im tmepted to go 19.5... but the wheel package is 2450.00.. maybe if uncle sam says yes...
I love suggestions.. we have hot August and cool April nights up here..and hundreds of old cars come out...this truck is a sleeper.. and the first ricer that runs with it will be surprised as it smokes the duallies until it runs out of top end...but the rumble at a stop light could be mistaken for a uncared for truck... wont they be surprised when all they see will be the rear lights.. ha
I didnt include pictures but Ill get some of the way cool turn signal/brake lights attached to the uppper light bar with chrome ford logos on them
<iframe src="http://s127.photobucket.com/user/notmeofficer/embed/slideshow/Son%20of%20mater" height="360" width="480"></iframe>
Old 04-13-2014, 01:47 AM
Xauterus Xauterus is offline
Xauterus is starting off with a positive reputation.
Really nice work you are doing there.
Old 04-13-2014, 09:38 AM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Very cool!
Old 10-08-2016, 04:16 PM
Ok.. got off my butt
Wrecker body all done.. completely coated in epoxy bedliner and then painted in dark root beer metallic urethane (summit brand.. and I give it 5 stars.. easy to shoot and came out great and is tough as nails). Scads of brackets braces pins and mounts were blasted and coated in matte black enamel. The wrecker body was painted in several coats (on top of the bedliner) and then received an additional coat of paraffin based undercoating... it runs into every crevice and doesn't retain moisture if a rock hits it.. it creeps and self heals
Did the old school safety stripe on the back deck
Still have to blast and paint the boom, the gumball and light rack, the wrecker arms, and rework the second winch to a late model one...
Tomorrow before I mount the body Im going to shoot the rear of the cab and lower rockers in bedliner
The bed is very "purdy" in the sun.... the metallic really sparkles (and this pic doesnt do it justice because you cant see the profile)
Who votes for 19.5 lo pros.. I do
But mommas disney fund says otherwise right now... such is life and balancing projects.. man toys.. and healthy marriage
Old 10-08-2016, 05:45 PM
ubereal2's Avatar
ubereal2 ubereal2 is offline
ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.
I just want a better picture of your Avatar
Unk Bob
Old 10-08-2016, 06:29 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
Nice job on the bed.
Quote:
Unk Bob
Old 10-08-2016, 10:44 PM
Quote:
Who could refuse a truck.. a gun.. and a girl
A truck will get you places and is just plain cool..
A gun will protect you and the truck and are just plain cool
A girl.... well she may or may not like the truck.. may or may not carry a gun.. which may or may not be a good thing.. and she may or may not refuse you all the time
My wife is twice as old and in better shape although the girl isnt bad... so Im lucky..but she wont let me put her on my avatar....
But
Shes does like the truck.. actually she likes this tow truck, son of mater, best of all our dents
And she certainly carries a gun.. and she doesnt care how much I spend on the trucks as long as I pay all the bills first
Im ok with that
By the way,, here is "l'il bit, my f600 frame off resto service truck I built .. Son of maters "dad".. Im just about done with it....
Old 10-09-2016, 09:27 AM
ubereal2's Avatar
MMMMm Ummmm!
Old 11-19-2016, 12:26 PM
Ok.. a little progress
Got the motor bolted down and transmission all mounted.. need to build cooler lines and mount a custom cooler.
Body is remounted on the chassis.. using better quality hardware..all grade 8 1/2 inch matching bolts.. improved on the universal mounting kit used to put these bodies on all makes in this vintage.. tied the rear trailer hitch into the frame so its a real puller now..instead of just off the body... which was plenty tough..but now its the way it should be
Built the new winch mount... now an easy to source 12k pound winch
Built out the mini push bumper... made 3/8" plate mounts welded to 2 x 5 inch tube contoured to the bumper... you can lift the truck by it. I also beefed up the ends of the factory bumper by installing tubular braces that come off the frame... I used dock bumpers for the push bumpers.. they are plenty tough... great for giving a vehicle a shove to push start or push off the road.. or road warrior is you're so inclined
Also added some ford oem tow hooks (that came from late models) all tied together frame to frame with 120 wall tubing..looks factory stock if you didnt know these trucks never had a tow hook option
Plan to mount the boom this week and do some wiring..
baby steps
Old 11-19-2016, 01:58 PM
Daveycracky's Avatar
Daveycracky Daveycracky is offline
Daveycracky is starting off with a positive reputation.
Wow, what a cool project. Nothing beats that slack jawed look of shock from those so easy to underestimate. *subscribed*
New truck in the shop 73 swb f600.. and the vin decode says? Notmeofficer Large Truck 12 11-29-2016 02:10 PM
The "I hate FTE" shop truck build Notmeofficer 1973 - 1979 F-100 & Larger F-Series Trucks 92 10-15-2016 11:56 PM
1967-72 Ford f500,600 etc heavy duty CAB for sale Notmeofficer Ford Truck Parts for Sale 3 07-12-2016 01:17 AM
Rust to an "Oregon oakie" is just valuable patina Notmeofficer 1973 - 1979 F-100 & Larger F-Series Trucks 41 06-06-2016 11:53 PM
Re-wiring the dentside... My choice Notmeofficer 1973 - 1979 F-100 & Larger F-Series Trucks 35 03-11-2016 03:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
