Idle problem
Old 04-26-2003, 03:06 PM
2speed's Avatar
2speed
2speed is offline
Idle problem
I just rebuilt a flathead, stuck it in, and it fires up beautifully, only it won't idle. I double checked timing, advance is working, carb has been rebuilt, actually by me after I thought that was the problem but it does the exact same thing.
The idle speed screw is all the way, the mixture screws are one turn out, and when I pull the wiper hose off it idles great, so it seems to be not getting enough air. I rebuilt the carb because I thought that it some dirt or something in it, but it acts the same way. Are the throttle plates supposed to be at least a little open? Mine seem to be shut tight....
Old 04-29-2003, 04:23 PM
Karm's Avatar
Karm
Karm is offline
Idle problem
The buttlerflys should be open just a crack.. otherwise it isn't sucking anything in. Your choke plate should also be wide open when it isn't running.
Old 04-30-2003, 09:01 PM
sosotwo's Avatar
sosotwo
sosotwo is offline
Idle problem
if you pull off the wiper vac. and it idles it would most likly be a vacume leak
Old 07-10-2003, 01:58 PM
fishin1976's Avatar
fishin1976
fishin1976 is offline
Idle problem
pulling the wiper vac creates a vacuum leak!
lvin4jc
15
06-06-2011 02:37 AM
yankeerebel
11-10-2009 06:56 PM
007bronco
Alternative Fuels, Hybrids & Mileage
12-09-2004 02:18 AM
bryan_johnson
07-27-2002 12:12 AM
thomase
02-07-2000 09:28 AM
Quick Reply: Idle problem
