Torque Pro?
Torque Pro?
Hello,
I want to make sure that I'm adding the PID's and equations correctly from the list that Tugly provided us (Thanks Rich).
I'm using a Tab3 7", if it makes a difference.
So when I go to the "Mange custom OBD@ PID's"
and then "Add Custom PID" screen a new window opens.
The first window on my screen says,
"OBD2 Mode and PID(in hex-eg:'01 OD' for speed) or empty if [internal_pid]'is used in the equation
Question is, is this where I put the (PID number)
For example from Tugly's list FIPW#221410
Thanks for the help,
Brice
Brice
Hello,
Brice
Brice
So for your FIPW example...
First line is 22140
Then the long name, Fuel Injector Pulse Width
Short name FIPW
Minimum 0
Maximum 6
Scale X1
Unit type ms
Equation ((A*265)+B)*.008
OBD Header Auto
Nothing under Diagnostic start or stop, then OK or Save.
You should look at your PID's before hand too, they may be close or you may just want to edit the customs that come with the "Add Predefined Set" of Ford PIDs.
11-17-2012 10:34 PM
Heater51
08-17-2012 09:55 AM
78FordTruck78
08-15-2011 08:55 AM
