Lots of Codes!
#33
Ok, being this is a thread for codes. Where would one find a complete list of codes for cross reference? I see you guys pulling codes and explaining what they are but how are you determining their physical origin?
P.S. This may have been covered before in another thread sorry just haven't found it yet.
#34
I have a list in the manual I got at Pep Boys. It gives the number for gas or diesel and a short few words of what it is. My problem is knowing what to do then. My AE gives the description after the code it registers too. But in many cases I need someone to point me in the right direction to look for the cause of the problem.
That is the success of FTE. There are so many good people here that will take the time to give some advice or suggestions for what to do. Even being older I can still fix things if I know what to look for and what to expect. My last few repairs paid for my AE and saved me money as well.
I remember seeing a list here somewhere but I am not sure where I saw it. I looked but didn't find it. I will keep looking. Maybe somebody else knows where it is.
#35
Here is a list of codes from superdutypsd..com
Ford Powerstroke Diesel DTC OBDII Diagnostic Trouble Codes- Powertrain P Codes | Superdutypsd.com
#36
Yes the tube needs cleaned to. Take a piece of weed trimmer string and feed it through the pipes, spray with brake clean first if you can't feed it through there. Put it in a drill and spin away.
People will correct me if I am wrong but I am pretty sure that sensor works in conjunction with the EBPV on the turbo pedistal.
Bubba Jones
07-01-2017 10:02 AM
