Need HELP with Recon LED taillights
Old 04-11-2014, 05:19 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
I finally bought led tail lights from Recon. They look good but they have issues. Occasionally they hyperflash!!! It drives me crazy and I want to fix it.
According to the recon website no resistors are needed. But when I called he said I need a resistor.
What can I do? If a resistor, what kind? Where to put it in?
Thank you for helping me out.
Old 04-11-2014, 10:25 PM
aregis30's Avatar
aregis30
aregis30 is offline
Recon sells replacement resistors also you can try local auto parts
Old 04-11-2014, 10:35 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
They do have resistors and some users with the same truck use them as plug and play and it works.
So should I add resistors still?
I am very bummed.
Old 04-12-2014, 01:06 PM
aregis30's Avatar
aregis30
aregis30 is offline
yes they can be replaced your easiest it to call recon let them know that you get hyper flash with your lights you got from them it might just the resistor is defective the ones I got from them had a bigger resistor it just might need that
Old 04-12-2014, 04:28 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
They worked fine today. Awful yesterday.
Recon is not reachable until Monday.
Where are the LED guys and Recon users?
Old 04-13-2014, 09:42 PM
Raul B's Avatar
Raul B
Raul B is offline
i have had 0 problems with the ones i have on my truck. they are usually pretty good about warranting their products. call them up tomorrow and see what they say.
if you have any problems getting a hold of someone email me at Stealthautomotive@gmail.com and ill see if i can help you get it resolved
-Raul
Old 04-13-2014, 10:09 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
Thanks Raul.
They worked fine all day today. And the only thing I did not do today is plug my phone in via USB. But that can't be it.
I will call them tomorrow and tell them what happened.
Old 04-13-2014, 10:44 PM
cford716's Avatar
cford716
cford716 is offline
-Raul
I am interested to see what they say or do. I have looked at Recon for a long time now but have been hesitant on buying from them because there are many posts about poor quality and very poor customer service.
Old 04-14-2014, 07:01 AM
sammy77's Avatar
sammy77
sammy77 is offline
I've had them on a couple of my trucks, and both worked flawlessly. I would not hesitate to buy them again.
Old 04-14-2014, 12:37 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
Recon will send me resistors to add. That is their solution. Which doesn't explain why it works occasionally and with no problem with other people.
Old 04-18-2014, 02:46 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
Can the trucks have their flashers changed out for solid state LED flashers instead of the mechanical flashers that cause this hyper flash issue? I know that's a recommendation for alot of vehicles, and a much better one than adding resistors (which should always be last resort).
Old 04-18-2014, 04:10 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
I was told there is no flasher in the new F-150's. Who can confirm that?
And it was blinking fine for 4 days and started back up hyperflashing yesterday.
Not all the time and sometimes it flashes fast normal normal fast normal fast fast fast....
Old 04-18-2014, 05:06 PM
RigTrash601's Avatar
RigTrash601
RigTrash601 is offline
So they are sending resistors, still no reason why. If you find out, please pass that along, curious to know.
the stranger
2004 - 2008 F150
08-08-2012 12:30 PM
DEATHDEALER666
1997 - 2003 F150
04-04-2010 05:16 PM
Jim McCarty
1999 to 2016 Super Duty
02-28-2009 08:10 PM
Antacus
02-28-2005 08:12 AM
target practice
Electrical Systems/Wiring
07-30-2003 10:39 PM
Quick Reply: Need HELP with Recon LED taillights
