Won't Boost past 11 PSI No Power
Hey guys,
Now that I finally got the truck running again (twice) I have decided to start dealing with the original issue: THe truck is gutless and will not boost past 12 PSI. It runs OK-ish at about quater throttle but when floored it just won't boost or accelerate for crap.
Info on the truck:
2003 6.0
Garrett Powermax
EGR Delete w/ SCT egr delete programming
Stock Tune
Straight Pipe
Stock Intake
Replaced EBP sensor and MAP sensor.
Replaced Intercooler with used good one
replaced CAC boots
truck held 20 psi of air with replaced intercooler
tried different used stock turbo
NO CODES
This truck is driving me crazy...
Info on the truck:
2003 6.0
Garrett Powermax
Stock Tune
Straight Pipe
Stock Intake
replaced CAC boots
NO CODES
Hey all,
Sorry I haven't responded in a very timely manner, I didn't get any notifications so I thought this went unnoticed.
There is no exhaust smell what-so-ever.
ICP at WOT= 3500 psi give or take
IPR at WOT=.71
VGT=.40 sometimes a little less
I can hear the turbo spool up
Boost gauge reads -1.30 at idle and gets to about 10 at WOT
Data from a SCT livewire TS.
Also, as a side note the truck has a little puff of black smoke when first flooring it but no smoke afterwards. (It's a stock tune)
IPR at WOT=.71
Hey all,
IPR at WOT=.71
IPR at WOT=.71
koeo ( key on engine off )
low ( idle )
high (2500)
OK,
KOEO:
VGT=.00
BAR=26.37 hg
MAP=26.65 hg
Idle:
VGT= .69
MAP=26-27
BAR=26.37
@2500
VGT= .43
MAP=28
BAR=26.37
There was no option to view EBP..but I feel like I was told awhile ago the 03's don't read it or use it or something? Sensor is new...
Also, forgot FICM readings last time. Ignition V 12.5 volts FICM output 48.5. Also tested with a meter awhile back and got a soild 48.5 volts.
KOEO:
VGT=.00
BAR=26.37 hg
MAP=26.65 hg
Idle:
VGT= .69
MAP=26-27
BAR=26.37
@2500
VGT= .43
MAP=28
BAR=26.37
yes for Bar not for map , on a cold soak your map bar and ebp should be within 5 psi here's the values
MAP koeo=14 ( 96) lo=14 ( 96 ) hi=15 (103 )
BAR koeo=14 (96.5) lo=14 (96.5) hi=14 ( 96.5)
EBP=koeo= 15 (103) lo=16 (110 ) hi=16 (110 )
if you see VGT at 80 anytime wot or high Idle then turbo is suspected values
VGT=koeo-0 lo=73 hi=43
I'm not sure how to enter PIDs, or if its even possible using the livewire. I may be able to borrow a snap on computer at some point. What could cause the high readings? I have already replaced the MAP.
Also, I'm not sure how relative this is, but I unplugged the sensor if the intake i believe its the MAF sensor? The only code this gave me was an intake temperature code..don't know if this helps at all..
