Need Exhaust System Recommendation...
Just acquired a new rig yesterday. It is a 2006 F-250 Super Duty King Ranch FX4 with a gas V-10 engine. I'm looking to replace the existing OEM exhaust system with a nice new, deep, loud, growling system. I've been looking at FlowMaster and MagnaFlow, but cannot decide between the two. Does anyone have any recommendations? I'll also be adding a cold-air intake, electric fans, and under-drive pulleys to assist with the power and mileage a little. Thanx.
All you really need to do is cut out the stock muffler and replace it with what ever you like. The tailpipe is 3" mandrel already. That is what I did on my 05. Swapped in a Dynomax Super Turbo. #17792. I kept the stock air box but replaced the filter with a cleanable style. A chip would probably be you best bet.
I'm close to finally pulling the trigger on something for my '05 3V V10 and so far my favorite videos were posted by rdinmv in this thread (Dynomax vt):
https://www.ford-trucks.com/forums/1...a-6-8-a-2.html
Prior to 2005 the 2V engines like my '02 V10 had a different exhaust set up, so I'm not sure how accurate videos of all the 2V exhausts compare to what a 3v would sound like with the same system.
Crawl under your truck and look closely at the existing exhaust, which was improved greatly in 2005, which in part explains why my '05 is rated at 50hp more than my '02 was.
At this point I am leaning toward just replacing the stock muffler with a Dynomax VT and leaving the rest in place since I miss the sound I had with dual glasspacks on my '86 Bronco with a Crower cam yet prefer not to spend more $$
There are many YouTube videos out there to listen to which mostly show how different the V10 sounds especially at high revs. Unfortunately most go from full idle to WOT with no load, which is not the best indication of what it sounds like going down the road.
You have many options for your F250 from where you can buy Parts of your choice.
some links given below.
Ford F250 Exhaust - Performance Exhaust Systems, Dual Exhausts, Tips & Mufflers for Ford F250 Super Duty Trucks - XLT & PowerStroke - 1965 - 2014
Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more
Electronics, Cars, Fashion, Collectibles, Coupons and More | eBay
