5.4 power help. - Ford Truck Enthusiasts Forums
5.4 power help.
Old 04-11-2014, 09:40 AM
huskybro huskybro is offline
huskybro is starting off with a positive reputation.
5.4 power help.
I just picked up a 05 f 150 with a 5.4. Is there any tricks or tips to make it come more alive. nothing to radical, just needs a little more spunk.It is a 4x4 with 150k on it. Thanks
Old 04-11-2014, 09:46 AM
CaptFX4 CaptFX4 is offline
CaptFX4 is gaining momentum as a positive member of FTE.
Quote:
Programmer would be the best start. I have an Edge that's custom tuned but just factory canned settings woke the truck up.
Quicker shifts and even saw a small bump in mpg's.
Old 04-11-2014, 09:54 AM
Thanks is there any specific one to get.
Old 04-11-2014, 10:18 AM
I have the Edge Evolution. Had that in stock form for awhile then added CAI and exhaust and had to get the tunes changed so truck wouldn't run lean.
If you have no mods the Edge will serve you well. I liked it for the fact that you can monitor different parameters of the truck such as tranny temp and coolant temp. Helps me when I tow.
Just search for edge evolution and it will be for 04-08 years. Comes with a mounting pod that sits on the left side of dash.
Others use SCT tuners but I have no experience and can't comment on them.
Old 04-11-2014, 03:20 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
I run SCT X 3 with custom tunes from 5 star tunening truck runs great caned tunes are not as good as custom call mike at 5 star great to deal with and a site sponcer
Old 04-11-2014, 10:58 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Bolt On:
  • SCT Tuner
  • Full Exhaust
  • CAI (waste of money, but sounds/looks cool)
  • regear to 4.30 or 4.56
little known fact, but the 4.6 3v and 5.4 3v motors are identical. except for the cubic inches. so all the fun stuff that bolts to a 4.6 3v works on the top end of the 5.4 3v
Internal work:
  • CMCC Deletes (get rid of the butterfuly CMCC crap for free flowing heads)
  • Detroit Rocker Cams (Brenspeed) or the FRPP Hot Rod Cams (good for about +30 rwhp)
  • Supercharger (instant +100 to 150 rearwheel horsepower)
your best bang for the buck is going to be tuning and regear. your current truck has a 85-100 hp loss through the drivetrain (typically 210 RWHP when dyno'd). Tuning will correct alot of that with the transmission and get you around 230-240 RWHP. Regearing is going to make your truck feel like an instant +30 RWHP. The mechanical advantage is amazing...and as a side bonus, many guys actually see better MPG's in the city since the motor is working less
the 5.4 3v is a great motor. wish I still had one. I've had 5 of the modular motors...I do at least have the older/bigger brother...the mighty 6.8
2009 or 2010 f150????????? J tothe Roc 2009 - 2014 F150 6 01-23-2015 09:01 AM
2007 E150 4.6 to 5.4 engine swap possible 2007E150 1968-2013 Full Size Vans 2 09-05-2014 06:03 AM
Rim size 2003 f150 2003 5.4l General Automotive Discussion 0 06-09-2014 09:58 AM
200k mile maintenance 98powerstang 2004 - 2008 F150 14 03-25-2014 10:47 PM
2010 5.4L Performance Mystery beeser 2009 - 2014 F150 1 08-03-2013 08:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
