Hopefully you get it from a donor vehicle. The hinges on newer gates are smaller so take the hinges. Also take the strikers. Hinges are a 2 bolt swap. Strikers you need to remove your "U" shaped factory striker and locate and drill for the bolt strikers. Also pick up some quarter sized washers to fine tune the hinges incase the gap is too big. Also some to extend the strikers out from the bedwall. The newer gates are a bit narrower than the pre 87s.
