New F150 Survives Ovens, Freezes and Salt - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Old 04-10-2014, 09:26 PM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Old 04-10-2014, 09:45 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
I was worried about how it would hold up to acid, phew, I can sleep good tonight
Just kiddin, great video
Old 04-10-2014, 10:09 PM
paredneck33's Avatar
paredneck33 paredneck33 is offline
paredneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to behold
Yeah that's a great video. I just wonder when they will release the actual ratings for this truck. Also I found it interesting that Ford has been using the Davis Dam area for tow test for over 30 years. And that is the place of choice for the new standardized tow tests that all the manufactures will be required to use. That bit of info should shut those TFL idiots up.
Old 04-10-2014, 10:39 PM
RigTrash601's Avatar
RigTrash601 RigTrash601 is offline
RigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputation
Quote:
You're saying the other guys may have to "put up, or shut up?!! UH-OH
Old 04-10-2014, 11:11 PM
CuNmUdF250's Avatar
CuNmUdF250 CuNmUdF250 is offline
CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.
Quote:
Originally Posted by Troy Buenger View Post
Here's a new video... Maybe some can rest a bit better now.
Watch the 2015 F-150 survive ovens, freezers and salt. With some acid thrown in. - YouTube
how I`m gonna rest better.... now I`m stressed thinking about how I have to convince my wife we need this truck!!!!
Old 04-10-2014, 11:18 PM
Quote:
Better to ask forgiveness than permission!
Old 04-11-2014, 01:31 AM
CGiron CGiron is offline
CGiron is gaining momentum as a positive member of FTE.
Good torque
Ford has not revealed the horsepower or torque specs for this new engine, which was designed from the outset to be equipped with automatic start/stop technology. But I just witnessed this engine on a dynamometer at Fordís testing centre in Michigan as it ramped up from idle to full throttle and stayed there. It didnít take long for the twin turbos and exhaust to start glowing red from the heat, but more interesting was the torque figure on the computer in the control room: 345 lb.-ft. from 2,500 to 4,500 rpm, which is right in the sweet spot where power is needed ó and more than the current 3.7-litre V6, while only slightly less than the 380 lb.-ft. in the 5.0-litre V8.
Ford engineers try their best to break new F-150 | Driving
Old 04-11-2014, 05:59 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Cool vid, thanks for sharing! I'll wager t hat some of these clips make it to the initial set of infomercials that Ford will use when she finally starts coming out.
Old 04-11-2014, 10:15 PM
CuNmUdF250's Avatar
cant wait for this truck.....I wont be the first to get one but I`m already considering it a done deal
Old 04-11-2014, 10:38 PM
Which engine setup are you leaning towards? I would imagine, with the lighter truck, the 3.5L EB will be something to behold!
Old 04-12-2014, 12:40 AM
CuNmUdF250's Avatar
honestly just imagining my `13 700lbs lighter makes me think the 5.0 will be the ticket.....but I`ve never driven a ecoboost....for my purpose however more economical is better so most likely 5.0 since its cheaper and gets better mpgs.....will be buying used though hence the reason for not being one of the first to get one
Old 04-12-2014, 07:54 AM
No doubt, I've only ridden in a EB powered 150, never driven one. It's impressive, but the V-8 rumble of the 5.0L, who needs a radio?!!
Old 04-13-2014, 11:21 PM
Soko179's Avatar
Soko179 Soko179 is offline
Soko179 is starting off with a positive reputation.
Thanks for the video and I can't wait to get behind the wheel of one. Now if they would let us know the towing specs.
Old 04-14-2014, 09:25 AM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.
I hate to be the one negative person here, but I'll believe all of the claims after the new truck has been on the road for a couple of years. Every time a new model comes out the manufacturer claims it was torture tested for "X" amount of miles without any problems. But, after the production models hit the roads most of the time problems arise that should've shown up in the testing(ie. cam phaser knock,vibrations, ect.).
The new F150 is looking better every time I see one, but I'm not going to get too excited just yet.
Old 04-14-2014, 09:34 AM
I'm definetly "smelling what ya stepping in cuz" I won't buy the 1st generation of a new series of anything. (so far anyway) I'll let them get the "bugs" worked out first.
New exhaust video(s) what do y'all thinK? CaptainJack_7 1987 - 1996 F150 & Larger F-Series Trucks 17 01-17-2016 09:11 PM
Cool F150 Commercials tcrote5516 1997 - 2003 F150 1 10-25-2015 06:38 PM
Manufacturing the New '15 F150 Troy Buenger 2015+ F150 2 06-11-2014 09:19 PM
I bet this really bothers some BMW owners. 640 CI Aluminum FORD 2009 - 2014 F150 9 09-05-2013 10:31 PM
New Vs Old F250 what is more survivable in accident greythorn3 General Automotive Discussion 143 03-11-2008 09:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
