New F150 Survives Ovens, Freezes and Salt
Yeah that's a great video. I just wonder when they will release the actual ratings for this truck. Also I found it interesting that Ford has been using the Davis Dam area for tow test for over 30 years. And that is the place of choice for the new standardized tow tests that all the manufactures will be required to use. That bit of info should shut those TFL idiots up.
Here's a new video... Maybe some can rest a bit better now.
Watch the 2015 F-150 survive ovens, freezers and salt. With some acid thrown in. - YouTube
Good torque
Ford has not revealed the horsepower or torque specs for this new engine, which was designed from the outset to be equipped with automatic start/stop technology. But I just witnessed this engine on a dynamometer at Ford’s testing centre in Michigan as it ramped up from idle to full throttle and stayed there. It didn’t take long for the twin turbos and exhaust to start glowing red from the heat, but more interesting was the torque figure on the computer in the control room: 345 lb.-ft. from 2,500 to 4,500 rpm, which is right in the sweet spot where power is needed — and more than the current 3.7-litre V6, while only slightly less than the 380 lb.-ft. in the 5.0-litre V8.
Ford engineers try their best to break new F-150 | Driving
honestly just imagining my `13 700lbs lighter makes me think the 5.0 will be the ticket.....but I`ve never driven a ecoboost....for my purpose however more economical is better so most likely 5.0 since its cheaper and gets better mpgs.....will be buying used though hence the reason for not being one of the first to get one
I hate to be the one negative person here, but I'll believe all of the claims after the new truck has been on the road for a couple of years. Every time a new model comes out the manufacturer claims it was torture tested for "X" amount of miles without any problems. But, after the production models hit the roads most of the time problems arise that should've shown up in the testing(ie. cam phaser knock,vibrations, ect.).
The new F150 is looking better every time I see one, but I'm not going to get too excited just yet.
