Is it possible to perform coolant flush without a Rad Vac?
Hello, I have a 2008 F250 approaching 75k and i would like to perform my coolant flush early. I am worried about front cover cavitation. Is it possible to do a proper flush without a rad vac? I see this is the preferred method but i do not own the kit. Also i bought the Ford gold coolant but not sure how much it will use. Also should it be pre-mixed? Thank you all in advance.
Yes this is possible, I did mine last year. It takes several hours to do it properly though. After the flush though I went with Rotella ELC coolant. You don't have to worry about silicate drop out like you do with the Ford coolant. Google 6.4 coolant flush....There's a few excellent how to videos.
