Carb Gasket 64 Ford F-100 - Ford Truck Enthusiasts Forums
Old 04-10-2014, 08:25 PM
Bigfatsteve Bigfatsteve is offline
Bigfatsteve is starting off with a positive reputation.
Howdy guys, I noticed my carb was sucking some air when I shot it the base of it with some gum out cleaner, while it was wet all of a sudden she started runnin real good! I pulled the carb off today after work and noticed their is only one manifold gasket under the carb? I could be mistaken but I think its supposed to have two right? One one each side of the carb spacer? Any advice would be welcome. By the way it's a 2-barrel stock carb on a 292 v8
Thanks Steve
Old 04-10-2014, 08:34 PM
skidoorulz's Avatar
skidoorulz skidoorulz is offline
skidoorulz is starting off with a positive reputation.
Yep 2 gaskets are needed
Old 04-12-2014, 09:03 AM
Jim Beckers's Avatar
Jim Beckers Jim Beckers is offline
Jim Beckers is starting off with a positive reputation.
You need Fel-pro #60048 for the base gaskets on the spacer. If you cannot find them local, check eBay. I was able to get two shipped to my door for around $3.
https://www.google.com/search?q=Fel-...sm=93&ie=UTF-8
Old 04-12-2014, 09:22 AM
Macs1964F100's Avatar
Macs1964F100 Macs1964F100 is offline
Macs1964F100 is starting off with a positive reputation.
Do you know anyone who sells the spacers? I want to and another spacer to try and increase low end torque.
Old 04-18-2014, 03:23 PM
Gasket
Thanks you were right! Works great!
Old 04-18-2014, 03:45 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
C3TZ-9A589-A .. 292 Carburetor Spacer (Motorcraft CM-454) / Obsolete
1963/64 F100/700 / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
C2AZ-9447-F .. 272/292 Carburetor Base Gasket (Motorcraft CG-187) / Obsolete
1957/64 F100/700.
NOS PARTS LTD has 5.
GREEN SALES CO. in Cincinnati OH has 13 = 800-543-4959.
VAN CLEVE FORD in Morton WA has 14 = 360-496-5999.
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 326 = 800-476-9653.
Old 04-18-2014, 04:44 PM
I called NOS and they wanted $179. That included shipping. The manager is going to call me back if they can do better on the price. I only have $200 in the carb with a fresh rebuild so $180 for the spacer is a little hard the swallow.
Thank you for the research. I will call one of the others if NOS does not come back with a realistic price.
Old 04-18-2014, 09:23 PM
Why not check eBay? I am sure you can find a good used spacer for a much more reasonable price. There was a 64 F100 at our Pick N Pull that had a spacer. Maybe check in your area for the same.
Old 04-18-2014, 11:42 PM
Did'ja call the other two sources to find out what their prices were?
Carb rebuild - '83 oneowner83 Ford Inline Six, 200, 250, 4.9L / 300 2 05-02-2014 03:16 PM
240ci Carb Replacement zpsull01 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-22-2013 04:00 AM
finding autolite carb parts crazed87bronco 1967 - 1972 F-100 & Larger F-Series Trucks 7 02-07-2012 09:08 AM
4180 Carb. Mounting Gaskets Chumbucket Fuel Injection, Carburetion & Fuel System 2 03-18-2008 03:56 PM
Help w/rebuilt carb on 292 -y-block 1964_mezajd 1961 - 1966 F-100 & Larger F-Series Trucks 8 04-13-2007 03:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
