Oil pressure gauge tap location
Old 04-09-2014, 11:01 PM
clong's Avatar
clong
clong is offline
Is there an easily accessible location on the 5.4 to tap into to run a mechanical oil pressure gauge? If so, pics would be very welcome.
Old 04-18-2014, 07:48 AM
clong's Avatar
clong
clong is offline
WOW!? 99 Views and no one knows of a place to tap into to check oil pressure? Besides the oil pressure switch, of course.
Old 04-18-2014, 12:15 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Heres what I did on my 2000 Expedition....I took off the factory oil pressure switch, used a hose barb in that location from there I installed a high pressure high temp hose to a T-fitting so than I can install the factory oil pressure switch and my Auto Meter sending unit...it works great....I also used a bracket to mount the T-fitting to the frame and out of the way of any movement of the steering or suspension.....I should of taken pictures of the install I did. Hope this helps...
....Gage
jcm46
6.4L Power Stroke Diesel
10-24-2008 07:28 PM
toolbeltdiva
01-13-2008 08:04 AM
460f350
12-08-2006 07:34 PM
F250OBX
Electrical Systems/Wiring
06-05-2006 08:33 PM
AKESPY
05-23-2004 02:14 PM
Quick Reply: Oil pressure gauge tap location
