Check Engine Light
Thanks for the last 2 replies.
I will check the fuse, that might be a reason for no stored codes.
Regarding the overheating: I don't think the engine is overheating, because the light came on just when I drove for a couple of minutes. If the heat sensor gives a false alarm, that sounds possible. I will look into that.
