2006 F-150 4wd module not working - Ford Truck Enthusiasts Forums
Old 04-09-2014, 03:17 PM
my05mustang my05mustang is offline
my05mustang is starting off with a positive reputation.
Hi,
I have a 2006 F-150 Supercab King Ranch 4wd. The 4wd is not working. Took it to the dealer and they tell me the 4wd module is not communicating with the PCM. It is my understanding that this problem is rare...like 1 in a million. Ford wants to replace the entire PCM.
In the past, I have had electrical problems with this vehicle due to corroded wires. Any advice would be much appreciated before I go and spend 1500.00.
Thank you!
Old 04-09-2014, 05:42 PM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
Check the iwe solenoid first. About 15 bucks and you can always take it back
Old 04-09-2014, 06:42 PM
Thank you. It's not the IWE. Wished it was.
Old 04-10-2014, 08:38 AM
The only other thing would be the hubs... id take it to a second ford dealership and get another opinion
Old 04-10-2014, 06:12 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
Quote:
Just hubs and iwe? There is much more to that system than just those 2 pieces.
I also recommend a second opinion. I would go to an automotive electrical specialist ( if your near Manchester,ct I can recommend a great one) I would suspect a bad wire or wires abd some in-depth testing is needed to diagnose. Could be the switch,motor,trans case and any wires in between. Sorry I don't have the answer, but it may be easier abd cheaper than a pcm
Old 04-10-2014, 10:56 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
I would get a second opinion. Ford generally doesn't have problems with modules or PCM's. Connections and wires are a different story. The F150's have been known to have transfer case shift motor problems. I owned an 06 that had that problem when it was 2 years old.
Old 04-11-2014, 12:57 PM
Quote:
I quite understand thats not the only things. I listed things that I knew and that ive had problems with and those are the majority problems. I dont want to list things ive never had an experience with
Old 04-13-2014, 08:09 AM
Thank you for your help. I live in Illinois. Lots of rust due to salt. I tend to agree with you that it is not the pcm, but very well could be bad wiring or a hub. I did inform them that I have had wiring issues. The problem with most dealers is that they prefer to change parts until they find the bad one.
One more question: do you know if it's possible to reprogram the pcm? Could be a dumb question.
Thanks again!
Old 04-13-2014, 10:38 AM
Thanks again!
You can reflash it but a dealer has too
Old 04-13-2014, 12:33 PM
One way to tell if the shift motor is bad is to switch it to 4wd. Then get under the truck and smack the shift motor with a hammer. If it engages 4wd, you likely have to replace the shift motor. That's how the tech checked mine. After the shift motor was replaced everything worked fine.
97 5.4 into 98 4.6 swap help 98f1404wdgreen 1997 - 2003 F150 8 06-11-2016 10:29 PM
ECU/PCM cause 4x4 to not engage? Ford army 86 Modular V8 (4.6L, 5.4L) 3 09-18-2015 02:58 PM
2006 ford f-150 4wd light packerfan2323 2004 - 2008 F150 4 11-05-2014 04:11 PM
4wd module? toothpaste86 Ranger & B-Series 0 05-03-2012 08:54 PM
Code p1740 Ted Wolf 1997 - 2003 F150 1 08-22-2005 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
