2005 Lincoln Aviator
Few questions,
Are sockets , etc, SAE or Metric ?
Going to change brakes & rotors and need to buy or borrow tools. I think you need a star socket to remove brake pads, what size is it?
Also looks like a shield or something has to come off to remove front rotors? Looks like larger size bolts, what size are these?
Thanks for the help
Thanks for the help
You will not need a star socket to remove the brake pads. That should just require a 10mm socket or box end wrench. These can get pretty tight over time so a 6-point is best. It might be 12mm, I don't have a clear recall. You might need a Torx (star) socket to remove a rotor retainer bolt, but I don't recall that being an issue on my Aviator. To make clearance to remove the rotor you also need to remove the caliper mounting bracket which requires either a 15mm or 16mm socket and probably a breaker bar as well. They are thread locked in place from the factory.
-Rod
-Rod
jcmac
11-12-2001 07:44 PM
