DPF-R 4.0 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF-R 4.0
Old 04-08-2014, 10:14 PM
AndyW86 AndyW86 is offline
AndyW86 is starting off with a positive reputation.
DPF-R 4.0
Need help. Recently tried to install the Gear Box Z 4.0 dpf delete and it would download for about 20 mins and then say error code 88. any help thanks
Old 04-09-2014, 06:08 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I think you need to contact gearbox z on this one. There are several that have the DPF R but no know has ever indicated any problems that I am aware of.
Old 04-10-2014, 11:27 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
I would contact Gearbox on this. I had an error code when I tried to install mine. I called them and they told me to turn the key to the run position before I plugged in to the diagnostic port. I did and the programmer loaded.
Old 04-16-2014, 11:18 PM
DrtTrkr's Avatar
DrtTrkr DrtTrkr is offline
DrtTrkr is starting off with a positive reputation.
When I put mine in the voltage was low. I put a charger on the battery when I did the download and then it worked.
Old 04-17-2014, 10:20 AM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
I used a gear box before I got my sct and it came up with an error code. Cant remember the exact code but I called them and they sent me a new one over night and sent them the old one back. They will take care of you.
changing DPF myself szpieleusa1 6.4L Power Stroke Diesel 13 02-08-2017 09:23 PM
DPF Delete and EGR Block Plates Serik 6.4L Power Stroke Diesel 10 06-30-2015 11:34 AM
DPF-R 4.0 Error Code AndyW86 1999 to 2016 Super Duty 3 04-08-2014 10:05 PM
DPF Delete POST EPA Preventing Sale of Tuners 08 F450 6.4L Dually 6.4L Power Stroke Diesel 32 03-03-2014 04:51 PM
Gearbox 4.0 and DPF delete StanleyZ 6.4L Power Stroke Diesel 19 04-25-2011 05:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
