Aerostar spare tire carrier in a F-1 panel
I was able to get a spare tire carrier off of my Dad's old Aero-star that I scrapped. I lined it up on the F-1 frame in the same location as the original carrier. Had to add angle iron crossmembers to support it.
I didn't want to put a hole in the rear splash in order to access the crank on it so I decided to go through the rear floor. This way the spare can be let down without having to get down on the ground.
I got a sink drain to use through the hole
I got a 90 degree drill adapter and removed the chuck, i then welded a nut onto the threaded end, this will go in the crank tube. The nut was ground to an oval so it would catch in the tube.
I attached it to the drain with PVC pipe and fittings.
And here it is installed.
A 5/8 deep socket is used to crank down the spare.
Total cost was about $25.
The carrier was trimmed as marked.
Carrier was centered on the original tire carrier Eye bolts and centered side to side.
I added the angle iron where needed to hold it. If this doesn't give enough to go on let me know and I'll try to get better pics.
Doc
05-05-2019 11:14 AM
Texas Chain Ring
10-05-2012 12:44 PM
LONG EL
29
01-17-2012 11:55 AM
thordehr
13
12-26-2010 11:04 AM
