Trouble Starting & Rev's Up on it's own - Ford Truck Enthusiasts Forums
Old 04-08-2014, 10:38 AM
TiffanyLJ TiffanyLJ is offline
TiffanyLJ is starting off with a positive reputation.
Exclamation Trouble Starting & Rev's Up on it's own
I think I have two separate issues. My 2008 Ford F150 with 75,000 miles has a new battery oh 4 months old or so but it is having trouble starting. It starts but it struggles at times. If I shut it off and start it again it starts up just fine- no problems. However, if it sits for a few hours and I try to start it, it acts as though it doesn't want to--it doesn't just fire right up like it should. My husband tested the voltage on the alternator and it is fine. I read online to check the fuses, fuel filter, and spark plugs. Is this correct and is there anything else I should have my husband check while he is at it?
Additionally, my pickup now likes to 'give it the gas' and rev up without me initiating it. Meaning, I barely put my foot on the gas pedal going slow and all of a sudden I get a jolt of power and the RPMS increase quickly then within seconds it goes back to normal. I did this three times in a row in less then 2 minutes then didn't do it again for a few days. It seems to only happen when I am driving 30mph or lower but more frequently when I am driving 5mph give or take in parking lots. Do I need to have my husband check belts or anything to fix this and would this be in any way related to my problem above? would it be a fuel issue? A couple months ago we switched from using Unleaded 85 with the 10% ethanol to Premium 91? with no ethanol.
2001 Ford Expedition idling low and can't find the root of the problem Jennifer Turner Modular V8 (4.6L, 5.4L) 7 09-24-2015 11:13 AM
09 F150 Loss of Power on Acceleration FordGirl2009 2009 - 2014 F150 2 07-28-2015 04:07 PM
How bad is Ethanol gas for our trucks? 87-XL-Squared 1987 - 1996 F150 & Larger F-Series Trucks 29 03-07-2015 12:23 PM
Ethanol, some of you guys just don't get it Dino@his Dad's Alternative Fuels, Hybrids & Mileage 294 10-21-2014 02:17 PM
87 F150 Fuel system trouble? CG8841 1987 - 1996 F150 & Larger F-Series Trucks 8 03-13-2014 05:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
