Replaced the cps a little bit ago cause the motor would shut off and restart but now with the gas peddle held steady it with surge a little bit. Would that be the tps? And what's a good brand to get if so?
Best way to answer your question is with a scanner. Hold the pedal as you say, and see if the TPS % (or voltage) wavers. If so, yeah, that fingers the TPS. You could even do this with the key on, engine off.
