Calipers E350 Super Duty Cutaway - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 04-08-2014, 05:23 AM
kalrez kalrez is offline
kalrez is starting off with a positive reputation.
New to forum, Original Post in wrong section (sorry for cross post) . Need help with difference between these 3 Left Front Calipers
BRCF-184
BRCF-185
BRC-7-RM
I put my VIN into the Ford Parts Website and it says all 3 are for my Vehicle (along with others that are Loaded etc.)
These are for a 2006 E-350 Super Duty Cutaway Chassis ( Winnebago Motorhome Not that MH Mfg Matters).
OEM Caliper Currently in place has a seized Piston (phenolic).
Can't find any description that tells me what the difference between these 3 is other can a sizable cost difference between the BRC-7-rm and the other 2.
Are the Piston Diameters the same ?
Is any one designed for higher capacity ?
Appears all 3 take the same Disc Pads.
Thanks for helping
Link to the 3 Parts
http://www.fordparts.com/Commerce/Pa...20Super%20Duty
Old 04-08-2014, 07:15 AM
Rick1025 Rick1025 is offline
Rick1025 is starting off with a positive reputation.
The 1st one is a new OEM caliper w/o the pads/ the 3rd is rebuilt/ I don't know about the 2nd,but would guess its "loaded" ( with pads)
broke fuel/water separator drain lever 99expyTN 6.4L Power Stroke Diesel 24 05-02-2015 10:34 PM
Correct PCV for 1992 460 ?? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 2 08-24-2014 05:35 PM
Steel OEM brake line...can't figure it out iridektm28 2004 - 2008 F150 1 07-31-2014 10:33 PM
Brake Caliper Parts Help kalrez 1999 to 2016 Super Duty 0 04-07-2014 12:34 PM
hpop gasket part # rideracelivemx7 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-01-2011 10:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
