64 solid front axle and motor/trans for sale/free
Hey guys,
I have pulled the stock front suspension (solid axle and leafs) from my 64 and started with my CV front end swap. Doesn't have the steering box or arm, but does have the drum brakes and steering linkage downstream of the arm. Free to a good home, pick up only.
Also have a 292 with 3 spd trans that I have pulled for a motor/trans swap. Motor ran when removed (don't they all!) and trans shifted fine. Had a starting problem that I believe was solenoid or starter motor related. I have pulled the drivers side head to inspect the cylinder bores, so some assembly is required to run it. Cylinders look in good shape. Will need some accessories such as carb and plug wires. $500 for motor and trans, OBO, picked up.
All is located on NW side of Houston Texas. Thansk.
I will keep an eye out for it. I travel between San Antonio and Houston most weeks and several counties north of San Antonio some weekends. I assumed someone borrowed it with out asking. I have one in Wimbledon White and it is sweet. It is worth looking for.
In the meantime though, I have it tucked away in the back of the garage. If you want it, and it is just a matter of picking it up, I will let it sit and collect dust for the time being.
I remember you looking for this alittle while ago. I been keeping an eye out during my searches for parts/trucks hope it pops up for sale eventually.
