Radiator woes continue - Ford Truck Enthusiasts Forums
Old 04-07-2014, 11:38 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
Went to the trouble of pulling my radiator out because I thought I had a leak. All we found at the radiator shop was a slight leak in the petcock. Put a new one in and reinstalled the radiator. I filled the radiator and started the truck to burp the air out.....cap not on yet obviously. I watched like a hawk on the radiator and under the truck. Not a drip or drop at all. After about ten mins of running and letting the coolant circulate, I put the cap on. Instantly coolant started coming out of the overflow tube. This is a new 4# cap. The coolant wasn't even hot. I took the cap off...truck still running and coolant not even hot enough to blow out when removing the cap...and the overflow stopped completely. Cap back on, coolant flowing out overflow tube, cap off, stops again. I haven't even finished adding the coolant that came out of it back in yet. Never experienced this and I'm getting tired of this radiator. Any ideas because I have none on this. Thanks!
Old 04-08-2014, 12:05 AM
Forgot to mention that the radiator cools the truck just fine. No issues.
Old 04-08-2014, 12:34 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Have you looked down in the radiator to see if bubbles are coming up inside?
First I would test the cap. New doesn't always mean good.
Then I would put a pressure tester on the radiator to see how fast it's building pressure. If it's not hot but building enough pressure to blow past a 4# cap there might be more going on than just the radiator.
Old 04-08-2014, 07:05 AM
Normalbloke Normalbloke is offline
Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.
Seems like the cooling system is being pressurised some how. Head gasket?
Have you had a pressure tester on to see if it holds, then increases as you start the engine?
Old 04-08-2014, 07:58 AM
I'll check the cap. I haven't had a pressure tester on it. And it had a few bubbles when I was burping the system.
Again, I can drive the truck for how ever long I want. It doesn't get hot. Not even in a parade for an hour going from just idling every few seconds to going 2mph for a few more.
Old 04-08-2014, 08:05 AM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
Measure the depth of the radiator neck and compare it with the cap
I bought a new cap and it was a bit short
Old 04-08-2014, 09:25 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
Might be time for a leak down test.
Old 04-08-2014, 09:35 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Would have never thought of that! Great info.
Old 04-08-2014, 12:44 PM
53FOPAR's Avatar
53FOPAR 53FOPAR is offline
53FOPAR has a good reputation on FTE.53FOPAR has a good reputation on FTE.
Maybe drill a small hole (1/8 inch or so) in the thermostat? Allows coolant to bypass thermostat when engine not yet hot.
Old 04-08-2014, 12:54 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Quote:
But his problem has nothing to do with overheating.
Old 04-08-2014, 02:58 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
This may be stupid to ask and I sure don't mean to offend, but how full is the radiator tank, is there room for expansion?
Old 04-08-2014, 03:02 PM
wallster's Avatar
wallster wallster is offline
wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.
If I read it correctly you're running a 4 lb cap. I would bump that up to a 7 lb cap since increasing pressure raises the boiling point of the coolant. Raising the pressure should theoretically keep the coolant from puking out due to boiling. I don't know what motor or radiator you're running though.
wally
Old 04-08-2014, 05:08 PM
53FOPAR's Avatar
Quote:
Yeah, that's why you do it. The thermostat stays closed until engine temp is reached. That means no coolant runs from block to radiator. The hole allows the coolant to pass before the engine heats up and removes the pressure. Also helps when trying to get the air out of the system.
Old 04-08-2014, 05:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
All thermostats have some means of air bleed built in. If you hold them up to the light, you can see the seat or the disc has a wavy edge, or a notch cut in it to provide air bleed/minimum flow. The only exceptions are the kinds that have a separate disc to open/close a bypass.
Old 04-08-2014, 06:15 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Sounds like lots of air in the system somewhere causing expansion and contraction. Usually in the heater core. Drop the end of the overflow tube into a gallon milk jug and the cycle the engine hot to cold 3-4 times. You should get less in the bottle each time if you are getting the air out.
Coolant Overflow Reservoir Question kr98664 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 05-29-2016 06:47 PM
7.3 IDI - High Coolant Pressure and Leaking Head Gasket mytoys2037 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-18-2013 12:40 AM
Too much Water Pressure? Fr. Frank 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-18-2012 01:34 PM
What is best quality radiator cap... ? caseys Explorer, Sport Trac, Mountaineer & Aviator 14 11-01-2011 10:17 PM
Radiator leaks. Radiator Cap problem? jpjahn Cooling, Heating, Ventilation & A/C 6 07-06-2006 04:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
