Radiator woes continue - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 04-09-2014, 08:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I doubt it's pressure, just a surge from trapped air like Pete said.
  #47
Old 04-09-2014, 08:49 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
Ok, thanks Ross. I know your expertise is far superior to mine, on the flatty's
And the others as well. I just wanted to get a second opinion on my thoughts.
  #48
Old 04-09-2014, 09:20 PM
ALBUQ F-1's Avatar
postin' fool
LOL, it's all conjecture from 1,000 miles away
  #49
Old 04-09-2014, 09:31 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
I let the truck run for ten minutes before I put the cap on so it wasn't actually "cold". Wasn't on fire but warm. On the pressure tester....I tried but the tester kit came with several fittings. None would attach to my radiator. Also one of the folks I was talking to today at Dennis Carpenter said if the head gasket was blown out would be bubbling the whole time I was sitting there with the cap off and it wasn't so hopefully no blown hg.
  #50
Old 04-09-2014, 09:41 PM
Ok guys! I am glad to hear it. I hope nothing but the best for you Wayne!
I will wait for the good news! I hate annoying little thing like this! Get'er fixed!
  #51
Old 04-10-2014, 10:38 AM
Got a message back from Stant Engineering dept. The neck on my radiator is to deep. No cap is available. They confirmed that the cap is not making contact on the bottom lip.
  #52
Old 04-10-2014, 10:58 AM
ALBUQ F-1's Avatar
postin' fool
  #53
Old 04-10-2014, 11:46 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Ooooooh !!! Lots of fun stuff at that site Ross. Good ideas if you plan to move your fuel tank. Thanks!
  #54
Old 04-10-2014, 01:02 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Time to get innovative. Figure out how much addition you need to get the seal part of the cap down into the sealing part of the radiator neck and put your fab skills to work. That or take it to a shop that will install a new neck. My experience is that all of these old vehicles don't burp or bleed quickly.
  #55
Old 04-10-2014, 01:17 PM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
I cut a disc out of a sheet of rubber as a temporary fix and it's still there 10 years later
  #56
Old 04-10-2014, 01:32 PM
ALBUQ F-1's Avatar
postin' fool
Steel washers would do the trick, too, maybe with a rubber one at the bottom.
  #57
Old 04-10-2014, 01:40 PM
petemcl's Avatar
Still Learnin'
Note that LMC Truck has a radiator cap #43-0010 for $4.95 that is specifically for stock radiators only. That seems to indicate that it is different than regular caps.
  #58
Old 04-10-2014, 01:58 PM
Cool links. I feel better knowing that there are some things available. I'm going to try cutting me a rubber gasket to take up the difference. I appreciate all the time and input guys. Looks like we got enough pages to qualify for a nifty video ad in the thread...lol.
As I've mentioned before this area is horrible for business. Nowhere to get a driveshaft made or balanced. And the list goes on and on. The radiator shop that all us old car guys used just closed last month. Now all thats left is the one that everyone is scared of. When I did my radiator the other day I had to show up in person (after leaving the radiator for a week) to get him to do anything. And when I dropped it off he told me two days. A week was fine but I know him and know he's not trustworthy. Anyway, I stood and watched him check the radiator and he doesn't seem very capable. Hopefully I can fix this without having to go back.
  #59
Old 04-10-2014, 05:42 PM
raytasch's Avatar
FWIW, I just measured the original Ford script radiator in my '49 F4. It originally had the 226 CId flathead six. Measurement down to the seal ledge surface in the radiator neck is 3/4". Distance from the brass top seal and the lower rubber seal of the 4 psi cap is 13/16", non compressed. So, in my case, there is 1/16" compression.
  #60
Old 04-10-2014, 06:31 PM
Thanks Ray. I went by NAPA and dug around in the rubber washers/orings. Found a suitable piece and placed it on the ledge. Now when I put the cap on I feel the spring compress some when I mash down to tighten. I'll keep a check on it and see if it leaks.
overheating and bubbles in overflow bsetbuilding Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-12-2016 04:05 PM
Coolant Overflow Reservoir Question kr98664 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 05-29-2016 06:47 PM
Radiator overflow hose question chesster51 1987 - 1996 F150 & Larger F-Series Trucks 2 09-26-2015 03:10 PM
7.3 IDI - High Coolant Pressure and Leaking Head Gasket mytoys2037 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-18-2013 12:40 AM
Radiator leaks. Radiator Cap problem? jpjahn Cooling, Heating, Ventilation & A/C 6 07-06-2006 04:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
