Tires and Speedometer accuracy... - Ford Truck Enthusiasts Forums
Old 04-07-2014, 09:20 PM
Ltngdrvr's Avatar
Ltngdrvr Ltngdrvr is offline
Ltngdrvr has a good reputation on FTE.Ltngdrvr has a good reputation on FTE.
Speedometer has been off in my truck ever since it was new. Had the dealer check on it and was told it was within the spec range so ford wouldn't do anything about it. According to my GPS, the speedo is off by a little over 2 mph at an indicated 70, about 3.5%.
Today I went and bought some new tires, went up to a 285/70R17 from the oem 245/75R17 size.
My speedo is now almost perfectly on the money, maybe a half needle width off at 70 now.
This of course has also lowered the rpm's a little for a given speed.
Hope this all translates to a little better mpg's...
Old 04-07-2014, 09:55 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Check the speed in engineer mode. Before, it was probably close to exact.
The speedometer is programmed to be fast. That was my experience with OEM tires.
Now your truck is probably reporting slower than it is even though your speedometer now appears more accurate.
Old 04-07-2014, 09:59 PM
Ltngdrvr's Avatar
I check it by the GPS that I know to be very accurate.
Old 04-07-2014, 10:06 PM
kper05's Avatar
By truck I meant truck computer, not the speedometer.
Your GPS matches your speedometer now but you truck is now wrong.
That's my experience.
With OEM tires, my speedometer was off like yours but the truck speed matched two GPS units.
Old 04-08-2014, 07:37 AM
U235Fishin' U235Fishin' is offline
U235Fishin' has a good reputation on FTE.U235Fishin' has a good reputation on FTE.
As compared to two GPS's that nearly match, my speedometer has always indicated about 2.5 mph high at 65 mph with the stock Michelins.
Old 04-08-2014, 08:57 AM
Ltngdrvr's Avatar
I don't understand, the truck is "now wrong" ???
It was "wrong" before with the stock size tires, and now has been corrected with the taller tires, now the speedometer matches the accurate GPS readout.
Old 04-08-2014, 09:00 AM
Ltngdrvr's Avatar
Quote:
Yes, exactly what my situation was before adding the taller tires.
I believe ford purposely sets the speedometer up to read fast, causing miles to accrue quicker on the odometer, making the warranty miles run out sooner.
Old 04-08-2014, 10:22 AM
720Deere's Avatar
720Deere 720Deere is offline
720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future
Actually most people find that the odometer reads several percent low on the 2011+ trucks.
Old 04-08-2014, 11:15 AM
Ltngdrvr's Avatar
Quote:
Every person I've talked to or read forum comments from has claimed just the opposite, like me their truck's speedometer reads faster than actual mph and of course the odometer is fast too.
My dad's new F350 also reads fast.
Old 04-08-2014, 11:40 AM
F stock owner F stock owner is offline
F stock owner is starting off with a positive reputation.
The speedometer on my all stock-OEM Michelins 2012 F-350 has always been right on the money as indicated by two handheld GPS units and roadside radar speed signs. I like the idea of going into engineering mode to see what the computer actually "thinks" the speed is compared to the speedometer. I'll have to try to remember that.
2012 F-350 Lariat 6.7 CC SRW LB
Old 04-08-2014, 06:48 PM
kper05's Avatar
The point I'm attempting to make is the truck speed and speedometer are two separate readings.
By truck, I mean the truck computer (that you cannot see in normal mode).
My understanding, mileage, MTE, etc. read off the truck computer speed not the gauge.
http://www.ford-trucks.com/forums/10...ml#post9695824
Old 04-08-2014, 07:01 PM
720Deere's Avatar
You think that the speedometer and the odometer have to be calibrated the same.....how cute.
Old 04-08-2014, 07:03 PM
GridLine's Avatar
GridLine GridLine is offline
GridLine is starting off with a positive reputation.
I drove by a roadside speed radar yesterday. The speedometer was right at 45MPH and the radar read 43MPH. Thought it was kind've weird but, it makes sense they design the speedometer to read faster.
Old 04-08-2014, 08:18 PM
Dakster's Avatar
Dakster Dakster is online now
Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.
My speedo is off, my odometer is on the money.
Old 04-08-2014, 09:05 PM
Iowa Ford's Avatar
Iowa Ford Iowa Ford is offline
Iowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputation
Mine reads 2 mph fast too.
Speedometer/odometer help BrushPopper 1973 - 1979 F-100 & Larger F-Series Trucks 14 02-05-2016 03:12 AM
speedo off MIKES 68 F100 1967 - 1972 F-100 & Larger F-Series Trucks 8 07-29-2015 04:51 AM
Bigger Tires, should i adjust speedometer? 68cabby 2009 - 2014 F150 6 03-24-2015 11:38 PM
Axle Gear Swap - What Speedo Gear? 1972RedNeck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-13-2014 10:44 AM
Speedo Gear Issues (Yes, I searched) Social_Joe 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-04-2013 02:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
