International doesn't agree with Ford diagnostic, need opinions! - Ford Truck Enthusiasts Forums
Old 04-07-2014, 05:49 PM
jayc3169's Avatar
jayc3169 jayc3169 is offline
jayc3169 is starting off with a positive reputation.
So a quick recap:
All winter I've been having cold start issues. I've changed everything you can imagine (Check past threads listed below for details) but nothing helped (not even Rev-X). So I finally took it to the Dealership. They call me back a couple hours ago and said that all 8 injectors were bad and were dropping off, my fuel pressure was reading at 36psi, my water in fuel light was illuminated (Never has before!), and they had to do a manual compression test to see if compression was good. All totaled to $4,361.46. Injectors, I can do myself at a cost of $261.64 each from Ford. So I called International to see if they had them cheaper and when I told them what Ford said, the tech said he had never seen all 8 injectors go bad and that I should not let them change them until other things were ruled out (e.i. Fuel pressure regulator, fuel pump, and something else (I can't remember the name). He also said that they can't work on Fords. I ok'd the dealership to do the compression test on the engine and nothing else. Anyone have any feedback on what I should do? I've called and left a message with the guys at powerstrokehelp in Georgia. I live in Huntsville, Al, does anyone know a trustworthy 6.0 mech here that can diagnose this? I just don't know what to do!
Here are the other threads I've created on the subject:
http://www.ford-trucks.com/forums/13...ease-help.html
http://www.ford-trucks.com/forums/13...ter-rev-x.html
Old 04-07-2014, 06:10 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
I can tell you that 36 psi fuel pressure is absolutely no good for your injectors.
Old 04-07-2014, 07:05 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Get the truck home, add the blue spring regulator and recheck fuel pressure.
Josh
Old 04-07-2014, 08:16 PM
jayc3169's Avatar
Quote:
Could it just be the fuel pump or fuel pressure regulator?
Old 04-07-2014, 08:19 PM
jayc3169's Avatar
Quote:
Josh
I am, after doing some reading and what the tech at International said I'm not letting the dealership do a compression test. I've done the bubble test and heard it crank without starting and my compression sounds fine so I'll save my 500 dollars on that. The Tech at international said he would take a look for me but he can't use the diagnostic equipment that International uses because Ford's computer reads differently.
Old 04-07-2014, 09:31 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
I would certainly do as others mentioned and get FUEL Pressure up See how it runs then
If you had low fuel press for a long time then you might need 8 inject But Bring the System to PAR before making any Decision on inject
I would Almost test the Fuel Pressure myself at this Point
Old 04-07-2014, 09:33 PM
jayc3169's Avatar
Is there a tool I can get to do that or a parts list to make one?
Old 04-07-2014, 09:38 PM
BLADE35's Avatar
You can go with a Standalone gauge or Manual gauge
Manual gauge needs a Kit for WOT compensator
Sean would be the Go to guy on the Tool
Old 04-07-2014, 09:40 PM
BLADE35's Avatar
BLUE FUEL PRESSURE SPRING INSTALL
http://www.ford-trucks.com/forums/10...tructions.html
Old 04-07-2014, 09:42 PM
acf6's Avatar
acf6 acf6 is online now
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
please do not bring it to that powerstroke help idiot
Old 04-07-2014, 09:43 PM
BLADE35's Avatar
theres my pic in that thread Lower left side it the Spot to screw in the FP Tester or Sender
http://www.ford-trucks.com/forums/pi...ictureid=75606
Old 04-07-2014, 09:49 PM
jayc3169's Avatar
Quote:
Just curious, but why, he seems to know a lot. But looks can be deceiving I guess.
Old 04-07-2014, 09:50 PM
jayc3169's Avatar
Thank you, I'm looking them up now.
Old 04-07-2014, 09:51 PM
Runs-wifey's Avatar
Runs-wifey Runs-wifey is offline
Runs-wifey has a good reputation on FTE.Runs-wifey has a good reputation on FTE.
We have seen a couple of his truck in person, not impressed at all !!!
Old 04-07-2014, 10:00 PM
Bullitt390's Avatar
Quote:
There is a fairly good tester at Harbor Freight that will work for a basic test in a pinch and includes the correct adaptor fitting for the regulator housing.
Called an oil pressure tester kit, works just fine for diesel fuel...
Engine Oil Pressure Test Kit
Specs call for 40+ psi at all times, better to see 45+ psi even during WOT.
Blue Spring kit should push PSI well over 55+
Josh
6.0L - Difference between model years bismic 6.0L Power Stroke Diesel 34 12-29-2016 12:18 AM
Local Bullnoses for sale 1980Supercab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 12-08-2014 04:18 PM
Troubleshooting a "low power" condition bismic 6.0L Power Stroke Diesel 10 09-23-2014 08:17 PM
Has anyone seen my oil? Anyone? bkuuz1 1999 - 2003 7.3L Power Stroke Diesel 34 06-26-2014 11:30 PM
Ford finds ChiefM 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-30-2012 05:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
