International doesn't agree with Ford diagnostic, need opinions!
There is a fairly good tester at Harbor Freight that will work for a basic test in a pinch and includes the correct adaptor fitting for the regulator housing.
Called an oil pressure tester kit, works just fine for diesel fuel...
Engine Oil Pressure Test Kit
Specs call for 40+ psi at all times, better to see 45+ psi even during WOT.
Blue Spring kit should push PSI well over 55+
Josh
Josh
I haven't been able to get one yet. I'm still using the bully dog and I've been getting 0275 and 0278 codes while driving even when it warms up. Sometimes one at a time and others they are both at the same time. and still a noticeable miss. Rev-X and oil change actually made it worse! Now it will shut off when cold!
Fuel pressure was 38 psi I double checked what they want to do the truck: 8 injectors, Fuel pressure regulator (blue spring mod), Filters (even though they were changed 2 weeks ago, and clean my fuel pump assembly. I'm headed to get my truck, I'll probably do it all myself and pay myself $106.74 an hour LOL.
I too would suggest starting with the blue fuel pressure spring and then looking at the fuel pump.
When the one in the 7.3 croaked, I had plenty of warning, I just wasn't paying attention to the obvious signs.
With the 6.0, it took more pedal to get the truck moving and the throttle response was ridiculously inconsistent.
As soon as the fuel pump was replaced on both, I had a brand new truck again.
The Ford subject matter expert (apparently a legit senior engineering title at Ford) told me 50 PSI minimum at full power. The tester to simulate full power is a manual pressure tester with the gauge on a tee fitting, after the gauge is a ball valve with a .047" orifice to meter the fuel, and hose to send the fuel back into the fuel tank. You idle the engine, open the ball valve so that fuel gets bypassed back to the tank and read the pressure. 36 psi at idle will absolutely kill all 8 injectors or make them read bad. Get the pressure up to 60 psi at idle with the kit and start from there.
Brian
Brian
So here's an update. Went to pick it up and it won't even start now (would when I dropped it off but won't now) and killed the batteries. Waiting on them to charge now. But the tech said the all injectors were dropping and fuel pressure was slow at 38 psi, the fuel pump needed to be cleaned and a couple of the injectors are sticking open causing compression to get into the fuel (I've done the bubble test and saw no bubbles). All totalling to 9 hours of labor and a $3,791.67 bill and replacing all injectors. I've seen a couple of vid on YouTube about taking out and cleaning the injector spool valves and replacing all the o-rings. Should I replace them all or clean the ones I have?
on
I assume this is an 03 truck?
If so start with looking at icp based issues. Bad sensors and bad high pressure pumps with low volume output will make the ids think you have bad injectors. Mix that with low fuel pressure its easy to think its a simple injector concern.
I have seen a few truck with 8 bad injectors before but its not common.
#28
#30
