International doesn't agree with Ford diagnostic, need opinions!
#31
#32
#33
Here is some info about the injector system : aka HEUI.
Look at 2nd page of the PDF and you will see a shot of the injector.
EDIT : You may also want to look at page 30 & 31.
Here is a link to the page you can read it on
Hydraulically Actuated Electronic Unit Injector (HEUI) Systems - Injector
If you want use this link you can download it.. It's to big to upload to FTE.
http://www.google.com/url?sa=t&rct=j...61190604,d.aWc
The way the injector works on the fuel side is there is an intensifier
piston. That piston if the fuel pressure is low will bottom out at the
of the stroke and hit. What the right pressure does is keep the chamber
full or part full so that the piston does not hit at the end of the compression
stroke. The piston is driven by high pressure oil from the HPOP and controlled
by the FICM. It is returned by spring and fuel pressure.
So if you running so the demand for fuel is high and the supply pressure
is low the intensifier piston will bottom at the end. That is hard on both
the spring and the piston.
Sean
Sean
FossenRacing
03-27-2014 08:10 AM
bulla
154
08-30-2010 07:37 AM
Sidhewynder
05-27-2010 12:59 PM
