recommended source for injectors - Ford Truck Enthusiasts Forums
Old 04-06-2014, 11:33 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
Did a quick search, did find anything.
I'm' looking for a good set of new or reman stock injectors and a set of upgraded to gain some pulling power.
also what is a good affordable additive so that the low sulfur fuel wont mess them up
last turbo back exhaust to help with egts
Old 04-07-2014, 12:16 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Try browsing Clay's site RIFFRAFF FORD DIESEL PERFORMANCE PARTS best pricing and quality stuff in my opinion you'll find, he sells New Alliant, as well as FullForce Diesel rebuilds.
Other shops for injector builds I would recommend would be Rosewood Diesel, Swamps, or Performance Injection Systems(P.I.S) There are a few others but these have good reputations. Personally I like the fullforce.
I run powerservice products, white winter bottle, and grey summer plus I add ashless 2-stroke oil for lubricity.
Old 04-07-2014, 01:01 AM
scotttahoe's Avatar
scotttahoe scotttahoe is offline
Under Construction
scotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to beholdscotttahoe is a splendid one to behold
How often do you add the 2-stroke oil to your tank?
Old 04-07-2014, 03:13 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
What search term did you use, "HPOP?"
All joking aside, there's a TON of injector info out there to be found with a search.
Stewart
Old 04-07-2014, 04:48 AM
jetdoc's Avatar
jetdoc jetdoc is offline
jetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud of
I can't stress this enough....go NEW. If you can't afford new wait save the money and then buy new. I wasted money on a set of remans and personally I could care less what kind of warranty they offer. I have better things to do with my time than swap out injectors.
Old 04-07-2014, 05:07 AM
2 stroke man 2 2 stroke man 2 is offline
2 stroke man 2 is starting off with a positive reputation.
After a series of unfortunate events with swamps, I ordered my last set through advance auto parts. They are borg Warner reman. The computer had them listed at a crazy price, but I got them around $130 each because I like to haggle like that. We put them in on Saturday. I'm anxious to see about the long haul.
Old 04-07-2014, 05:33 AM
jetdoc's Avatar
Quote:
. Clay sells new AC Alliants for 213 bucks.....this is what I'm trying to stress to the OP. Do the job right the first time and be done with it.
Old 04-07-2014, 05:41 AM
I went reman because these trucks have been rough on me this winter.
My 6.0 dropped a rod at 70k and also had to have a hpop, my 99 dually has had injectors, turbo, valve cover wiring harnesses, icp, ipr, cam sensor, glow plugs, complete new brakes, 4x4 hubs and shift motor, tires, hpop, and some other stuff. So when my 01 got sick, I did tighten the belt.
Old 04-07-2014, 06:55 AM
jetdoc's Avatar
I feel your pain...I replaced the whole front end on mine and springs etc..When it all said and done a little over 3k....
Old 04-07-2014, 10:20 AM
Dan V Dan V is offline
Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.
Quote:
Originally Posted by jetdoc View Post
I can't stress this enough....go NEW......... I have better things to do with my time than swap out injectors.
What he said ^
Old 04-07-2014, 11:01 AM
Stewart
My search was only on this site, "good source for injectors"
that only brought up all the treads that mention injector
Old 04-07-2014, 12:27 PM
Y2KW57's Avatar
Y2KW57 Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
For those who have had problems with reman injectors, did these guys rebuild them?
If you survived and recovered from laughter, head shaking, shock, awe, good music, country boy talk (NSFW), great visuals on 7.3L injector components, and genuine fear of who is actually rebuilding the injectors you buy on some of these niche diesel speed sites, then here is part 2 of the video above:
(Caution: these videos, while on topic, do have a helping of typical "shop talk" that may not be safe for work, depending on where you work.)
Old 04-07-2014, 01:07 PM
Stewart_H's Avatar
That's extremely limiting. The OP might want a nice set of hybrids after all is said and done.
Not enough smilies?
I was just joshing with you.
There's a ton of injector info out there, but a person would have to weed through the ton just to get find the specific info they're looking for.
Stewart
Old 04-07-2014, 01:28 PM
Stewart.....can still have a "new" hybrid.
Old 04-07-2014, 05:19 PM
Stewart_H's Avatar
Quote:
That animal never existed.
Hybrids were never "made" as defined by the terms factory original (new from Alliant) vs. remanned.
I don't know it like the back of my hand, but in a nutshell, in order to make a hybrid stick, you take the plunger and barrel from a B code injector and stick it into an A code injector.
Hybrids were never available from injector manufacturers like Alliant. It's something diesel enthusiasts created.
Stewart
injectors dwf6119 6.0L Power Stroke Diesel 5 08-31-2015 01:05 PM
Reman injectors VS alliant new. Kdr358 1999 - 2003 7.3L Power Stroke Diesel 14 09-03-2012 05:30 PM
Rosewood Diesel Injector Review bubba_3711 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-15-2012 11:17 PM
6.0 injector cup brushes LKCKR 6.0L Power Stroke Diesel 0 11-16-2011 07:19 PM
Oily Injectors kpjr Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 08-18-2011 09:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
