General Diesel Discussion
Old vs new 7.3. Looking for info
Old 04-06-2014, 10:32 PM
Fordman96's Avatar
Fordman96
Fordman96 is offline
I'm back to the annoying mind battle of a 408 stroker vs a 7.3 diesel for my new engine in my 96' Bronco. Stroker is just, rebuild current engine, put it in, happy jolly blah blah.
Other option is to put the bronco body on a shortened f250/350 frame with a 7.3 diesel in it. I know the swap is possible with just a stock bronco frame, set the motor in, box the frame, new running gears, etc.
My thought however is just to do a whole frame swap, so then I have the upgraded axles, stronger frame, stronger drivetrain, etc.
The only question I have left is what 7.3 to choose from. 94.5-97 OBS 7.3 PSD or 99-03 PSD/SD 7.3.
What I know so far:
OBS: 15* HPOP, mechanical fuel, no intercooler, single shot injector
NBS/SD: 17* HPOP, e-fuel, intercooled, split shot injector, 4r100 trans (stronger than the E4OD)
Questions:
Upgrade ability? Chips/tuners, turbochargers, OBS will need e-fuel/intercooler
electronics. Can a 94.5-97 harness fit a 99-03 engine?
I hear the SD dash is larger, so it would require more modification to fit all needed electronics/computer/cluster in my current dash.
Any other information is greatly appreciated!
Old 04-17-2014, 08:28 PM
snowdog79's Avatar
snowdog79
snowdog79 is offline
How about finding an IDI OBS for the chassis swap? No electronics, easy to service, turbos can make some pretty good power. A F350 would be nice if you were into making the Bronco front end solid.
Jetmech6
1978 - 1996 Big Bronco
10-26-2014 04:13 PM
Lt CHEG
01-17-2013 10:01 PM
RFAgrasshopper
24
03-25-2012 04:36 AM
rollerstud98
01-10-2007 06:10 PM
Dave7.3
07-31-2006 08:55 AM
Quick Reply: Old vs new 7.3. Looking for info
