89 F-250 the mess
Old 04-06-2014, 07:19 PM
892504x4's Avatar
892504x4
892504x4 is offline
89 F-250 the mess
Here are some pic of the mess.
http://s895.photobucket.com/user/892...250/The%20Mess
If you need me take different pics let me know and thanks for the help.
Dave the exhaust smells of fuel after cranking
Old 04-06-2014, 08:18 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
First thing I would do is replace that POS aftermarket coil with a motorcraft coil correct to the truck.
Do you have spark at all?
Old 04-06-2014, 08:20 PM
892504x4's Avatar
892504x4
892504x4 is offline
I do not know about spark was getting mad so I walk away will rent spar checker tomorrow.
The fun it was running Friday drove the thing to work and back screwed it up looking for a vac leak
Old 04-06-2014, 08:27 PM
Old93junk's Avatar
Old93junk
Cause and effect...........You must have broken a connection while looking for the vac. leak, check things as easy as one end of the coil lead being just barely off, or the +/- leads to the coil.
Old 04-06-2014, 09:06 PM
892504x4's Avatar
892504x4
892504x4 is offline
It is going to take some time going through this thing just going to have to pull tape and loom looking every thing over. Discovered today that the wiring is a lot worse then I thought bad crimps and no solder.
Old 04-06-2014, 09:11 PM
Old93junk's Avatar
Old93junk
There is your problem...........Have the wife crank the truck while you twist/pull suspect connections, I bet she fires up at some point.
PS.......Watch your fingers, while cranking.
Old 04-07-2014, 05:34 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
Coil is junk.
Actually it's a good attempt at a MAF (Mass Air Flow ) system. Most of the wire mess on the solenoid is a bad 3 g alternator upgrade, rgm makes a kit you can fix all that with later on.
Looks like the 2nd biggest problem, your fuel injection wire harness is butchered. I think if you clean that up, you will get the fuel injectors triggering properly again. Another problem you may have, the mustang computer is grounded differently than the trucks, so you may need to work on some grounds. If he did anything half right, there should be a ground behind the headlights on the driver side, inside the core support, this is your main computer ground. The second computer ground comes out of the harness at the firewall, and attaches to the hood hinge right inside the fender driver side. I can take some pictures tomorrow if the rain lets up some, I have MAF on the 94 that I built the motor like yours for.
Old 04-07-2014, 08:15 PM
892504x4's Avatar
892504x4
892504x4 is offline
Thank You
I will look at the cost of the coil.
This is some of the crap I removed when 130amp alternator went in.
This is what I added the wire is over kill but bought it on a big discount short piece.
The rest of the crap at the starter relay is trailer wiring hack
Old 04-07-2014, 08:54 PM
892504x4's Avatar
892504x4
892504x4 is offline
Just checked no spark.
Old 04-09-2014, 07:14 PM
dustybumpers
Sorry for the delay Chris.
Been a horrid start for the week. Photobucket is locked up for me tonight, so I have to remember what we had.
I seem to remember a mess of red duct tape. What's under that?
Old 04-09-2014, 07:15 PM
dustybumpers
The bushman is your fuse for your 3 g alternator. that's a good thing.
Old 04-09-2014, 07:43 PM
892504x4's Avatar
892504x4
892504x4 is offline
Some of the things I have figured out with this thing The ECM is an X3Z from a 93 Mustang Cobra SVT and it has the Mustang 70mm mass air sensor and throttle body.
No worry on the delay not driving the pickup much.
The mess under the red duct tape is the stock ecm connector.
When I realized the mess on the alternator I knew i had some trouble coming.
If I get too concerned about the wiring any suggestion on what to get one from?
Old 04-09-2014, 09:06 PM
dustybumpers
I can hook you with an old thread I wrote on the alternator tomorrow, I'll dig it out, looks like you have the basics there already, just need a clean up.
Tomorrow I will also try to see photobucket again, and ask for more pictures. I really think bad coil right now, but a good clean up is needed too. We'll figure it out.
Old 04-09-2014, 09:24 PM
892504x4's Avatar
892504x4
892504x4 is offline
The alternator wire is 2 gauge running to a 175amp fuse the connected to the battery post.
Looking at the wiring tonight there are splices after splices and other dumb stuff tomorrow I dig out the soldering iron.
Old 04-10-2014, 08:14 AM
dustybumpers
Here ya go on the alternator. Start on page 3 post 32. Maybe Don can clean it up and make a work sticky somewhere so people can find it and use it
https://www.ford-trucks.com/forums/1...ator-help.html
Quick Reply: 89 F-250 the mess
