Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Lift gate locked tight
Old 04-06-2014, 06:24 PM
John R. Thomas's Avatar
John R. Thomas
John R. Thomas is online now
I bought spare Ford cap for our 75 F-150. The plan is to swap the back
lift gate. HOWEVER…the latch on one side is stuck closed. Locked, no key.
I unhooked the rod and moved it with a channel-lock wrench. The latch
assy. will not move. Cutting the parts by the latch with a saw-zall will
destroy the fiberglass. Am I SOL? Perhaps a big bolt cutter?
Did I write BOLT CUTTER? Today I used a bolt cutter to destroy one of the aluminum
latches held in place with big phillips screws. A chisel and hammer finished the job.
The latch parts on the edge of the lift gate are rusty.
I removed the bolts along the hinge line and was forced to destroy the slider on each side.
The spare/good lift gate is now removed. Next step is to repair the lock assy and the
rusty latches on each side.
QUESTION: What is the best way to remove those stubborn phillips head screws?
Drilling is last resort.
kansas gary
1999 to 2016 Super Duty
11-29-2016 10:34 PM
John R. Thomas
04-23-2014 07:43 PM
offroad_x
03-02-2011 03:33 PM
75Highboy460
02-16-2009 01:42 PM
Quick Reply: Lift gate locked tight
