How Do I Remove A-Pillar Trim? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 04-06-2014, 05:22 PM
kailor's Avatar
kailor kailor is offline
kailor is starting off with a positive reputation.
How Do I Remove A-Pillar Trim...driver's side 2000 Expedition. Thanks.
Old 04-07-2014, 12:27 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Lift upward while pulling it out.
Old 01-26-2015, 11:40 PM
flip72's Avatar
flip72 flip72 is offline
flip72 is starting off with a positive reputation.
2004 trim removal
Trying to do some work on my auction buy (2004 Expedition XLT) Would anyone know if this would be the same procedure to remove the pillar trim on a 2004 Expedition? trying to get the trim off behind the "o sh#t" handle looks like some kind of bolt on either end of the handle once you remove the little plastic "hole covers" but i don't see a nut or anything that a deep socket can get a bite on? Can't seem to find the proper search terms to find anything. Thanks in advance for any help.
Phil
Old 01-27-2015, 12:39 AM
Did you look in the hole with a light? I think they might be torx screws.
Old 01-27-2015, 11:40 AM
Skauber Skauber is offline
Skauber is gaining momentum as a positive member of FTE.
On mine it looks like really small hex bolts, almost looks like pins.. My smallest socket available in my set is 6 mm, and it was too big. Might be 4 or 5 mm, or maybe 1/4". I couldn't be bothered to go inside to get more tools, since my job was on the C pillar and I was just gonna pull the headliner down a little and I was able to get the job done without removing it.
If it's 1/4", that should be the standard size of the hex drive on screwdriver bits, so you may be able to use that. I think the trim will come off easily once the handle is removed, but can't say for sure as I ended up not removing mine.
Edit:
Well, just did the math. 1/4" is 6.35 mm so definitely not that. I'm on metrics, so I regularly mess up my inches...
Old 01-27-2015, 01:52 PM
flip72's Avatar
Quote:
Thanks alloro I couldn't find anything that looked like it would except any type of screw..
Old 01-27-2015, 01:57 PM
flip72's Avatar
Edit:
Skauber, we have a winner! looks like I was thinking deep socket ..(I didn't have any that deep and small) but after looking at what you said .. It made sense the whole brass piece is the "bolt" so It is a 7/32nd socket that fits right over it and it came right out! NOW wait until I ask you guys about this I found behind the trim (next post)
Thanks again guys!!
Old 01-27-2015, 02:08 PM
flip72's Avatar
OK this was tucked up behind the the trim?... This was a police SUV and they didnt spend a lot of time removing unneeded stuff when they sent it to auction.- part of what I was doing is taking out the spot light post. But this has one wire and heads into the dash (I will back track ASAP) looks like some kind of Transponder maybe? ANY thoughts some kind of standard sensor maybe? all thoughts are appreciated.
Old 01-27-2015, 02:52 PM
Could be an antenna for a remote starter, an alarm, a keyless entry, or something like that.
Old 01-27-2015, 06:51 PM
flip72's Avatar
found all kinds of stuff
Well on my way to follow the mystery wire, I found the speaker for the police radio behind the dash with a few zip ties holding it in.
and when I got to the end of the receiver/transponder looking thing it was not connected to anything. so I guess I'll hang onto it just in case.
ok well I am learning more about interior trim removal then i ever wanted to know.... and found yet more unexplained stuff (see next post) found a cord that goes even deeper into the dash.
Old 01-27-2015, 06:56 PM
flip72's Avatar
Not sure .. look familiar?
sorry if i went off in a different direction than the original post! chasing shiny things!
Old 01-28-2015, 03:36 AM
That last picture of the cable with SKN6365A on it. That's for a Motorola hands-free cell phone holder/charger kit.
Maybe that antenna was an booster antenna for the cell phone.
Motorola OEM Mobile Phone Car Holder for Moto T720
Old 01-28-2015, 12:23 PM
flip72's Avatar
Good call, I was able to remove two more cables out last night, The one with the number on it and an mini antenna type cable, looks like the sheriff had a hands free/charging motorola kit set up in the truck and when they sent it to auction someone in maintenance went to town with wire cutters. The good news is I got the trim off as requested, the bad news is I had everything so taken apart It just made sense to take out the stock cd/cassette radio... now I have to buy a nice double din size replacement , damn shiny things. Thanks for the ideas and thoughts.
Old 01-28-2015, 01:48 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
flip - I see you are in WA. One thing to be mindful of with trim work is, if possible, work on this stuff when the interior of the car is not freezing cold. A lot of these snaps and interference fits can break in the cold. It is much more forgiving when warm.
Old 01-28-2015, 02:40 PM
flip72's Avatar
Quote:
10-4 Sir! I'm getting to old for that cold weather stuff myself!
Removing A-Pillar Gauge Trim chrison600 Excursion - King of SUVs 3 10-28-2016 08:28 PM
A-Pillar trim replacement smoky_diesel 2011 & Newer Explorer 2 09-30-2015 01:05 PM
A-Pillar Guages (3) and Dash-Daq Sarge261 Ford Truck Parts for Sale 2 04-26-2015 08:12 PM
Trick to remove A-Pillar trim? 93nighthawk Aerostar 7 07-23-2014 12:23 AM
Removing A-Pillar TIKT B8 2007 - 2014 Expedition & Navigator 5 11-28-2010 12:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
