Battery light on - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Battery light on
Old 04-06-2014, 10:28 AM
gabsey gabsey is offline
gabsey is starting off with a positive reputation.
Battery light on
Gentlemen,
I have a 2011 F250 Super Duty w/116k miles. A week ago the battery light came on. Now the instrument cluster goes crazy, lights blinking, check everything, heater going full blast with heater off, windows dont work, etc. The everything goes back to normal for a while, including battery light goes off, then it goes nuts again. The battery tested out fine, wondering if anyone has any input on this problem. Either alt or some kind of something causing power surges, etc...
Old 04-06-2014, 07:44 PM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
Battery light on is usually a bad altinatot . . Good chance its hooked into instrument cluster to make it Act up. I know farm tractor instrument panels dont work when they go bad
Old 04-07-2014, 07:29 AM
Thenewboss's Avatar
Thenewboss Thenewboss is offline
Thenewboss has a good reputation on FTE.Thenewboss has a good reputation on FTE.
Quote:
Originally Posted by gabsey View Post
Gentlemen,
A friend of mine at work has a 2012 Mustang that did this same thing. Brought it to the dealer and they replaced the battery and hasnít done it since. Not saying the same thing is going on with your truck, just sharing the experience, good luck...
Battery Light On and Whining Noise from pulleys. ajschwab2004 2004 - 2008 F150 4 02-08-2016 12:08 PM
1999 ford ranger battery light brent1204 Ranger & B-Series 3 03-26-2014 10:57 AM
2006 Ford Escape Battery Light On - Voltage = 14! rivetc78 Escape & Escape Hybrid 4 04-11-2012 07:43 AM
Battery light comes on at low RPMS, goes off over 2k+ RPMs???? 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 1 06-04-2011 01:06 AM
Battery light on at start up Tim98TA 1999 to 2016 Super Duty 8 09-04-2010 06:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
