239 OHV Engine Question
The cover lifted high enough to see underneath with a flashlight and the baffle (or whatever that metal pan is) is wider than the opening. It is apparent that if I could turn the cover one way or another I would be able to get past the casting but I cannot.
Do you have any idea what the baffle is for?
I had to pull a head to get my 272 tray out . baffle keeps oil from sloshing around and running to the back of the motor when accelerating , Do yourself a favor remember to put the tray on the motor be for putting the heads on and rocker arms , push rods ,and headers .It will save a lot of dirty language ,
It is my understanding that the baffle actually serves as an air damper for crankcase ventilation. It should be left in place even if using PCV instead of a road draft tube.
With the cover flat on the block, shove it to one side and compress the gasket on that side and/or gently bend the raised flange that's in the way of clearing on the other side with a flat-head pry bar (er, screwdriver). some folks grind those raised lips down, but, they make the cover stronger and help to keep a seal. So, I wouldnt remove much.
Have fun!
Have fun!
I can assure all of you that the dang thing is not going to come out in useable condition unless ahead is removed. I give you that assurance because my wife evaluated it and came to that conclusion. I shall not argue with my wife as she has been inattentive to some of the expenses on Floyd.
If things change I'll let you guys know.
ghall
06-02-2007 07:07 PM
getuted
11-19-2004 06:51 AM
