Poor man block and radiator flush??? - Ford Truck Enthusiasts Forums
Old 04-05-2014, 09:12 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Well, I ran the truck last week and afterward I drained the radiator. I had flushed water through it ages ago, but when I drained the water out this time it had a rusty look to it. So, I got to thinking it would be good to flush it out real good with water.
Tell me if there are any problems with this method. I would pull the heater hose at the return side (no heater is attached) and run the engine and continue to feed water to the radiator and let it wash everything out.
Good? Bad? Dangerous? Stupid?
Here is how the engine sits now.
Old 04-05-2014, 10:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I doubt you'll get enough velocity to really flush the block that way. NAPA and other places sell a great cooling system flush, I'd use that, and after running it in the truck a while (per directions) yank the lower radiator hose off (obviously don't want the water to be really hot). Let it cool then flush a couple times with clean water, again pulling the hose so you get a good gush of water to sweep out the crud. If Y-blocks have block drains, open them too. Most of the crud settles at the back of the block, so facing downhill helps.
Old 04-06-2014, 07:47 AM
Harrier's Avatar
Awesome. Hopefully I can get that done today. Thanks.
Old 04-06-2014, 07:59 AM
1952henry's Avatar
1952henry 1952henry is offline
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
Get yourself some DAP wood bleach ( oxalic acid, what the old radiator flushes had as the main ingredient) from a hardware store. Mix 1/2 cup with warm water, stir to dissolve crystals. Put into radiator and run. Drain, flush with warm water, then fill radiator with warm water and add a box of A&H Baking Soda. This will neutralize the acid. Flush with warm water after the A&H treatment.
Old 04-06-2014, 08:40 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Always a good idea to remove the thermostat when cleaning a cooling system.
Old 04-06-2014, 09:11 AM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
That brings back memories of ''earl''!!
Old 04-06-2014, 10:21 AM
Harrier's Avatar
Quote:
Yep, Earl was my inspiration. Here is the video I posted in my build thread of the drive.
Thanks for the tips guys. Napa is 30 miles away, so I will try O'Reilly. Online they say radiator flush is not available. I will buzz over there and see since they are only a mile away. Depending on how that works I might try the bleach method next.
Radiator shop recommended soap flush ? annaleigh 1968-2013 Full Size Vans 23 01-05-2016 05:29 PM
My experiences with Gooch's coolant flush procedure AMG-SM 1999 - 2003 7.3L Power Stroke Diesel 28 05-09-2015 12:55 PM
Coolant Flush Macs1964F100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 06-04-2014 09:29 PM
Restore and Restore Plus chemical coolant questions...did I not flush enough? Boo_Daddy 6.0L Power Stroke Diesel 12 10-29-2013 07:53 PM
Cooling system flush 71FoMoCo Ranger & B-Series 3 02-21-2006 08:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
