Back in the Bio again! - Ford Truck Enthusiasts Forums
Old 04-05-2014, 05:40 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Just thought I'd share, it's been a long cold winter. Washing one batch of fuel and just started another. I miss my $1.20 / gal fuel...
Old 05-28-2014, 06:05 PM
jamusfam jamusfam is offline
jamusfam is starting off with a positive reputation.
I'm looking at doing the same I've invested into a 86 6.9 diesel. Let us know what you found was the best techniques and things that work best. I got 5 55 gallon plastic drums that I'm going to use collect and make.
Old 05-28-2014, 11:50 PM
Rushmore X's Avatar
Here are the steps I use:
1. Collect WVO
2. Filter WVO to remove large chunks
3. Fill reactor w/ 37.5 gallons of oil (using 50 gallon water heater)
4. Heat to 125 and add glycerol from last batch
5. Circulate and let glycerol settle out.
6. next day - drain glycerol, recover methanol from it.
7. Test Titration Levels of WVO
8. Heat WVO to 125 F and turn off heat
9. Add Methoxide (5 gallon methanol + about a gallon recovered from prior batch) to Heated WVO slowly, about 20-30 minutes
10. Mix the mixture for about 2 hours(pump mix)
11. Let it sit
12. next day - Drain off Glycerin from the bottom of tank, save for treatment of next batch
13. Recover Methanol then dry wash with Magnesol. Let set a couple days.
14. Filter bio
15. use bio
I pretreat due to some of my oil is rather acidic. by pretreating I neutralize some of the acidity. If you have really good oil you can skip this step, might want to anyway... I just seem to get better bio this way...
Old 05-29-2014, 11:39 AM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
I really miss making bio. Someday ...
Old 05-29-2014, 05:39 PM
Rushmore X's Avatar
I really need to find another source of oil, have enough for one more batch...
Old 08-07-2014, 03:38 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Welcome back Jim. I knew you wouldn't quit. I'm still plugging along. I don't recover my methanol. Pain in the butt. What is your recovery process? Maybe I am not doing it efficiently.
What happened with the methanol/KOH mixture? Did it get too hot? I notice the mix gets very violent when it is hot out. I leave plenty of ullage space when pouring in KOH and I do it in 2 steps (4gal methanol/2 lbs KOH)
I've been very busy so I don't get on this Forum much any more. I see there is a new "breed" on here now. Lots of WMO processors. I'll stick with WVO. Don't think I'll ever go with WMO. Fabman would "be all over me like a cheap suit" There are still some of us "purists" around.
Good luck with your endeavors.
Tom
Old 08-07-2014, 08:16 PM
Rushmore X's Avatar
I just recover the methanol from the bio. It does take a little time to heat up the processor to 185 and distill it off.
Yes, I did mix the 2 when it was near 100 out, you're right - very violent reaction. won't do that again...
Fuel pressure gauge install question Gear619 1999 - 2003 7.3L Power Stroke Diesel 2 01-16-2016 05:06 PM
Fuel question dobenator 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-03-2015 02:58 PM
"Water in fuel": Bad filter or bad fuel? AikenRooster 6.0L Power Stroke Diesel 15 06-27-2015 09:41 PM
Fuel tank filler neck teamlx88 Expedition & Navigator 5 06-15-2014 08:48 PM
Blue fuel in my fuel bowl dooleyservices 1994.5 - 1997 7.3L Power Stroke Diesel 8 12-28-2011 04:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
