I need to test data port
Old 04-05-2014, 04:15 PM
steam643's Avatar
steam643
steam643 is offline
Trailering
The DLC in my truck (97 f 250 Diesel) will not communicate with my Auto Enginuity Scan Tool. Before I start tearing things apart I would like to verify the pin voltages on pins #2 & #10. Between pin #5 and pin #10 I am getting 5 volts but pin # 2 has nothing. Is it normal? I would like to know for sure before I unplug the PCM.
Old 04-05-2014, 04:31 PM
fordpride's Avatar
fordpride
fordpride is offline
Are you having a issue with the AE powering up or does it powee up and not communicate
Old 04-05-2014, 07:20 PM
steam643's Avatar
steam643
steam643 is offline
Trailering
Software opens and works up to the last step then I get error that it can't communicate. Called AE tech support, that's how I knew to measure voltages. Very nice guy but they are software people not mechanics on old Power-strokes. Calling tech support also reassured me that I have the software set up correctly.
Old 04-05-2014, 08:26 PM
rodneywar's Avatar
rodneywar
rodneywar is offline
did you check the fuse for the dlc irrc they share the same circuit as the cigar lighter
Old 04-05-2014, 09:20 PM
steam643's Avatar
steam643
steam643 is offline
Trailering
Pin #16 has 12 volts. Lighter works
Old 04-06-2014, 04:19 PM
nomad221's Avatar
nomad221
nomad221 is offline
Is your rig chipped ? If so, you'll need to set the switch to stock mode if it is programmed or remove the chip completely from the ECM for AE to work.
Old 04-06-2014, 04:37 PM
steam643's Avatar
steam643
steam643 is offline
Trailering
I don't think there is a chip. I really don't know where to look for one.
1973FE
22
04-13-2019 11:56 PM
finallyo3gt
17
11-14-2015 10:43 PM
steam643
04-14-2014 09:36 PM
2004F250superduty4X4
1999 to 2016 Super Duty
05-28-2012 04:28 PM
77300i6
1983 - 2012 Ranger & B-Series
10-15-2007 08:55 AM
Quick Reply: I need to test data port
