Torque Converter Capacity
Old 04-05-2014, 11:49 AM
djmichael24951's Avatar
djmichael24951
djmichael24951 is offline
I am changing the Torque Converter in my 1995 Ford F150 4x4. It has the 4R70W. I need to know how much fluid to put in the new one before I put it in the transmission.
Old 04-05-2014, 12:23 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
With it laying down it will hold more than standing up.
It will take probably 2 quarts without spilling out, but lay it down to lube the whole inside.
The pump will quickly fill the tq converter on startup, so make sure you top off the trans while running, idling in park.
Old 04-05-2014, 03:23 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
X2 on that, also let the torque converter set a few hours after filling it before installing it. That will help the converter's lock up clutch pack soak with fluid and not have a "dry lock up" when it does.
Old 04-05-2014, 04:35 PM
djmichael24951
Thanks Fella's
gearhead5
08-19-2016 11:04 PM
JOHN2001
06-11-2012 05:55 PM
Jerrygroah
05-05-2007 06:54 PM
vulch
1983 - 2012 Ranger & B-Series
05-02-2005 09:28 PM
redneckdieselmechanic
02-17-2002 10:04 PM
Quick Reply: Torque Converter Capacity
