Need a little help
Old 04-05-2014, 06:40 AM
SunnyBeach's Avatar
SunnyBeach
SunnyBeach is offline
Need a little help
I just finished the wiring harness, everything works as it should, but I learned two things. First thing, the EZ wire harness is not EASY! but it works great. Next thing, the hood is very hard and I have knots and cuts to prove it. Is there any way to get it to raise higher? I also need to know where to get new sending units for both the oil pressure and water temp.
Old 04-05-2014, 10:40 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
It really helps us (and therefore you) if you put your truck's year and model in your Signature, which you do in the UserCP (control panel).
The BonusBuilt trucks (48-52) are not particularly generous in underhood access. But you can disconnect the support springs at the the hood connection, and raise it a little further, but you need to securely tie it up to the rafters or something. It's also really not that hard to remove the hood, which makes a huge difference. Leave the hinges in place if you do that.
Old 04-05-2014, 11:32 AM
AXracer's Avatar
AXracer
AXracer is offline
At the service station we always kept a broomstick handy. For major work, the first thing to come off was the hood.
Old 04-05-2014, 12:21 PM
SunnyBeach's Avatar
SunnyBeach
Sorry about leaving out what I'm working on. It's a 1950 F1.
Old 04-05-2014, 12:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Forgot to say, as far as the hood being hard, check all the hinge points. Spray them liberally with Kroil or other penetrating oil for a couple days, then go to a regular oil like 3-in-1 or similar light motor oil. If that doesn't help, you may have to take the hood off and work on the hinges and spring support. Make sure none of the hinge parts are bent.
Old 04-05-2014, 03:49 PM
SunnyBeach's Avatar
SunnyBeach
Are there any after market oil pressure sending units and water temperature senders that will work on the original gauges?
Old 04-05-2014, 04:44 PM
49willard's Avatar
49willard
49willard is online now
I do not know but you can use the original sending units with 12v+ but it is a good idea to install dropping resisters (should improve sender lifetime). I ran Willard, my 49 for years that way running a 55 Buick nailhead and will run Willard the same way with a stroked 350 sbc.
Old 04-05-2014, 06:03 PM
SunnyBeach's Avatar
SunnyBeach
When I got the truck the PO had already changed it over to 12 volt. The 6 volt wiring was burnt to a crisp, I'm surprised it didn't burn the truck. I installed a voltage reducer on the gauge panel with the new wiring harness. All the gauges will work if you ground the wire going to the sender. Direct reading gauges show 40 psi oil pressure and 140 degrees water temp. Could you tell which vendors would have the sending units that fit my old truck?
Old 04-05-2014, 07:54 PM
49willard's Avatar
49willard
Are you asking where to buy original Ford 1950 sending units, oil pressure, temperature and fuel level, that you can run at 12 v?
To my knowledge you will need to find used senders for oil pressure and fuel level. Dennis Carpenter sells new 6v temperature senders.
Old 04-05-2014, 08:23 PM
SunnyBeach's Avatar
SunnyBeach
Thanks for all your help, I will contact Dennis Carpenter.
Old 04-05-2014, 08:25 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Sunny,
Welcome Aboard! Nice to see another '50 on here.
One thing to note if you have the same temp. sending unit we had - that's not a wire that's hooked up to the temp. sending unit - It's a real small tube full of Mercury or some other nasty stuff. Handle with care.
Good luck over there.
Ben in Austin
1950 F1
3twinridges
11-06-2017 06:05 PM
BonesNis
06-01-2015 04:07 PM
427 fordman
04-18-2009 01:45 PM
dongc1
05-11-2004 02:11 AM
Quick Reply: Need a little help
