If I install a Manual choke do I remove the linkage? - Ford Truck Enthusiasts Forums
Old 04-04-2014, 08:06 PM
ericford1984 ericford1984 is offline
ericford1984 is starting off with a positive reputation.
If I install a Manual choke do I remove the linkage? I have a carter 1 barrel and bending the linkage and fast idle set is not working out well. So I'm thinking of installing a manual choke. Truck is strictly a beach truck so it's used may to august. So like I said just curious if I do install a manual choke. Do I still need to set up the linkage. Or can that be removed.. Thank you
Old 04-04-2014, 11:28 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.
I would remove the linkage to the automatic choke so it doesn't interfere with the cable for the manual choke.
Manual Choke Setup avellaneda13 Ford Inline Six, 200, 250, 4.9L / 300 1 10-26-2016 02:53 PM
Holley 4160 choke issue Brian4618 Performance & General Engine Building 1 10-30-2015 10:30 AM
Edelbrock MANUAL choke help! 67FEranger FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 12-12-2012 04:28 PM
Installing/Operating Manual Choke JoeHarbourJets 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-17-2011 04:03 PM
Choke pull off needed? PacoLips 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-06-2010 08:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
