#3 uplifter wired?
Old 04-04-2014, 04:23 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
#3 uplifter wired?
I was messing around the truck getting ready to do the high idle mod and found the #3 uplifter is wired to something-looks to be a factory connector--but have no idea where to begin to figure out what it goes to. The uplifters are factory and has the factory brake control right beside the uplifters. Any idea's on where to start to find out what this switch is wired to?
Old 04-04-2014, 04:45 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Anything that was wired in by original owner would be where to look, trace the wires, backup lights, iPod charger, previous high idle are all possibilities....
Old 04-05-2014, 10:51 AM
Corner Gas's Avatar
Corner Gas
Corner Gas is offline
Could also be heated mirrors, that is what I have my #3 switch wired for.
Old 04-05-2014, 11:21 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Good point. I have factory heated mirrors but havent figured out how to turn them on or if its automatic? I have flipped the switch but cant find anything on---mirrors could be it
Old 04-05-2014, 11:23 AM
Green96's Avatar
Green96
Green96 is offline
I may be wrong but I believe that in stock form the mirrors turn on automatically for a while when the truck is first started. Someone may have hooked them to a switch so they could turn them off, because why do you need heated mirrors in months like July.
Old 04-05-2014, 11:41 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
True too. Would have figured there would be an indication like when they were on but I havent seen anything yet? Whatever the uplifter is hooked to is cab forward best I can tell so far.
Old 04-05-2014, 01:48 PM
meetre's Avatar
meetre
meetre is offline
On my 04 the heated mirrors turn on when ever the defroster is on. Some guys would wire power to an up-fitter switch to turn them off when wanted.
Old 04-05-2014, 01:51 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
You must have an excursion
Sent from my Telegraph using IB AutoGroup
Old 04-05-2014, 11:34 PM
Corner Gas's Avatar
Corner Gas
They come on when you start the truck. I have mine hooked to the switch so I can turn them on only when I need to. I got tired of my mirrors being covered in water spots in the summer.
Old 04-06-2014, 06:03 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Thanks kinda what I was thinking.
Old 04-06-2014, 10:11 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
You can simply pull fuse #39 (05 and up trucks) to disable the heated mirrors in the summer time, or install a switch.
Old 04-06-2014, 01:01 PM
meetre's Avatar
meetre
meetre is offline
Or I'm an ID10T and need to pay more attention. Just went out and checked and they do turn on when the truck is started. My have to buy some switches and wire it to turn it off now.
Old 04-06-2014, 01:14 PM
npccpartsman
Or you can pull fuse #9 like I did and replace it when it turns cold again.
Old 04-06-2014, 02:42 PM
meetre's Avatar
meetre
meetre is offline
That just seems to easy!
saddlethunder
03-03-2019 08:52 PM
Powerstrokin_350
1999 to 2016 Super Duty
11-14-2012 10:32 AM
sscarboro
10-28-2010 03:33 PM
mattd17
Aftermarket Products
11-24-2005 01:35 PM
ForDen
01-08-2003 09:13 PM
Quick Reply: #3 uplifter wired?
