Running Out of Fuel
Running Out of Fuel
2003 F350, 6.0---Changed both fuel filters, cleaned out pump, cranks good idles all day but when you rev it up to 1500 and above it acts like it is running out of fuel, let off and it will catch up and idle good. if you dont let off it will die, cycle ign a couple times and it will crank back up and run good. also going down road if you let it idle or maybe run about 1000 rpm it will go but if you try any more than that it goes dead. does anyone have any thoughts of what i might could try next. Thanks.
If, this all started immediately after the filter change....
Double check your filters and the housing cap, especially the lower! If the lower doesn't fully seal it'll suck air like you are experiencing.
Happen to me last filter change, i have a fuel pressure gauge so i don't risk injector damage from low fp.
Sent from my Sprint PC36100 using IB AutoGroup
Mars57
08-30-2012 05:16 PM
