OEM Toolbox
OEM Toolbox
Was there ever any OEM or dealer accessory toolboxes offered on these trucks for mounting under the hood?
My 70 F250 has a small....maybe 16" long, 8" wide 6" high toolbox mounted very professionally on the left side inner fender, in front of the original jack holddown.
Either it came with the truck originally, or some PO did an exceptional installation.
Right now it is swimming in a washing soda bath, if it was original I will put it back, if now, one more thing I can toss.
Good Job Orich. The basic number on that box is 46100. Taking that 46100 and going in to my Ford 1964/72 micro-fische, Ford listed the bedside box,in-cab box which took the place of a gas tank, and a on the bed rail "contractor's" box. AKA what everybody buys now-a-days. But no under the hood one.
on
I make the rounds one a week to pnp when weather is good.So my eyes are always open.
I was once going to install one of those bronco under the hood tool boxes, but don't want to give up my dual batteries for one.
I still had a small for many yrs when, I had a c/o camper on for many yrs.
Since removing camper remove it. Now just use the one behind the seat one.
orich
orich
This is said toolbox, and where it sits. First 3 pics
Ford Truck Enthusiasts Forums - Serfbored's Album: Garage - '70 CS
on
Wow that's a tool box for sure. I used one about 1/2 that size. Just had a few hand tools to get by with extra set of points feeler ga, one extra spark plug, some plies two types of screw drivers plug wrench. Some tape & bailing wire, Nuts & a few bolts. Always carried my tool box in the camper if needed out on the road. Plus having a camper on your truck you seem to haul everything you'll every possibly need and never use most while camping..
orich
orich
HMMM. I've seen that wiper reservoir before. It is not the normal one for a Bump. I think it's the one Ford lists for a Power Pack. Out of curiousity where the bolts that go from the mount brackets to the inner fender, are those holes looking like a PO drilled them or do they have some Ford threaded inserts?
No threaded insert of any type, but the holes, in the toolbox, brackets and inner fender all look cleaner than PO drilled holes, they kinda look factory punched.
Orich, I see you mentioned baling wire and tape.....when did you own a Chebby
