No trailer running lights on 2002.
My mom and dad are an hour away on a camping trip. When dad hooked up the 5'er to the truck, he checked and all lights were functioning. He came out got in and went down the road.
As he was traveling he noticed he didn't having running lights. Brake controller was functioning and brakes themselves were working. He called a his friend who was following him and checked if he had turn signals and break lights, and that was fine.
So he called me after unhooking. He checked connection in the bed, as well as on the bumper and neither one will run the trailer lights. He jumped the connector on the trailer like all of the people in my camping group do in order to get the running lights on while we are camped (a tradition my brother, father and I started). Running lights on the trailer work fine when jumped so it's not the trailer. He checked fuses with a meter number 6, 17, 18, and 38 (going off memory here) and they were all good. Number 115 which is a bigger one (not a relay) with a plastic window and is supposedly for trailer battery charging was blown so he went to Autozone to get some fuses.
He hasn't reported back whether or not that fixed it for him. I do't think 115 is going to be it. So what now? Anything I can tell him to check before he has to run the truck to an automotive electrical place?
Yeah. If you take a little wire and jump the top 2 contacts together one on each side of the alignment lug, voila...lights.
If you are looking at the plug, the plastic alignment lug on top, the contact to the upper right is running lights, the contact to the upper left is 12V. Jump those 2 and the running lights are on. When you are plugged in to the camp's 120 service, it keeps a charge on the batteries, and you have lights. It's just something I saw once and I thought something was wrong with the guys camper. So my dad, brother, and I went over and told him and he chuckled. He said he saw a plug selling on ebay for about $20 that did it. He said he was pretty sure it was 2 wires jumped inside the plug but he didn't know which 2. My brother did a little research and found out which to contacts it was and I keep a little 14 gauge wire and once we set up, I jump those 2. I like it.
I think your recommendation of dielectric grease was likely spot on. He may want to pull the plug off the truck end and make sure the wiring behind isn't starting to rot.
What amp fuse do you use? Does anyone running the lights all night long have any issues with bulbs burning out or lenses getting too hot and distorting?
Melanie Ross Thaxton
2009 - 2014 F150
19
09-25-2023 12:29 PM
Kelpy1
03-09-2017 09:31 PM
falloutboy89
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
07-11-2016 08:32 AM
Kuttysark40
09-19-2004 09:53 AM
